Re: Official EF SEDAN SQUAD Thread
Rob.; so amazing. Still can't believe this is your winter beater and you live in CA to boot.
Get ready for some more whoring Had a blast today with Ashley (photographer) and Thuy (model). Ashley took over 500. The EF'n Maniac's is hers. The rest are mine. More to follow.
Looks good. What header is that?
I didn't think anyone would notice
Thanks dude
Thanks dude
bored to 84.5mm
JDM ITR pistons
310cc injectors
Skunk2 IM
Omni 70mm throttle body
3" ebay cai
Toda rep header
14" Vibrant ultra quiet resonator
Tanabe Medallion exhaust
i don't really care about the numbers though. I considered cams, but after being turbo, the minimum gains I'd get just doesn't seem worth it lol
B18c1
bored to 84.5mm
JDM ITR pistons
310cc injectors
Skunk2 IM
3" ebay cai
Toda rep header
bored to 84.5mm
JDM ITR pistons
310cc injectors
Skunk2 IM
3" ebay cai
Toda rep header
heres my build..
b18c1
stock bottom end
96 ITR cams,valves ,valvesprings and retainers
hondata intake mani gasket
skunk pro i.m.
toda rep header
stock prelude h22 obd1 injectors
walboro 255
tuned on hondata s100
183 hp 131 tq
I bet if you add ctr cams, you'll gain 10+
0x5359-0055
Blu, what's the compression ratio on your motor? Engine management? Stock GSR valvetrain, correct?
My bad guys, I meant 81.5mm
According to Zeal, my compression is 11.7:1. Using NepTune and stock valvetrain. I considered BC Spec III+ cams like I had on my B16b, but after being turbo, meh. lol
0x5359-0055
Damn, was hoping you were rocking a Hondata setup, your map would at the very least get mine started, then could play with it from there. Base maps seem to be few and far between, guess nobody likes to share.
0x5359-0055
Finally shipped off my ECU for Hondata's RMA process, hopefully they're able to fix whatever the hell is wrong with it. Worst case scenario, I drop an extra $250 and have them upgrade me to the V3.
Sorry job hadn't checked the updates since that post. Your sedan is looking great as always. Blu you as well! @myef you decide you coming to houston yet?
My linkage came in! The innovative v2!
Also found some replacement pistons for the b20. Coudnt source one on its own so I waited until I got all 4 with rods for a twennny!
Good news ! Found the drivers side moldings at civicdutyparts, brand new ! They had a set left in stock ! They are ordered and already shipped. !
I also found thr entire right side in Belgium. Those will be ordered Monday as it is a holiday there.
F.Y.I. 88-91 civic/crx Oil Filter Manufacture Database
Made a list of 88-91 civic/crx oil filter manufactures with part number.
Please add to list.
thanks
WIX - 51334
DENSO - 150-1006
BOSCH PREMIUM FILTECH - 3312
BOSCH WORKSHOP - 72228WS
BOSCH DISTANCE PLUS D3312 (Blue and silver can)
BALDWIN - B1402 (for crx 1.6) 14 psi - 117 sq inch long media
BALDWIN - B161-S (for civic 1.6L) 1/2" longer can, 20 psi - 198 sq inch long media
NAPA PLATINUM - PFL 41334
NAPA GOLD - FIL 1334
NAPA SILVER - SFL 31334
K&N - HP-1004 (Heavy Duty and Construction)
K&N - PS-1004 (Synthetic and converntional oil)
K&N - SS-1004 (Billet aluminum housing, washable-reusable)
HAMP Synergy - H1540-PFB-515 (Short Japan made)
HAMP Synergy - H1540-RTS-505 (Taller USA made)
PUROLATOR PUREONE - PL14459 (Gold can)
PUROLATOR PREMIUM - L14459 (White can)
Mobil 1 - M1-104 (extended oil interval)
MICROGARD - MGL51334
AC DELCO PRO DURAGUARD - PF1127
MOTORCRAFT - FL-810
ROYAL PURPLE - 10-2808
FRAM HIGH MILEAGE - HM3593A
FRAM TOUGH GUARD - TG3593A
FRAM EXTRA GUARD - PH3593A
CARQUEST - 85334
STP - S2808
PENNZOIL PLATINUM - PZ-37 (yellow can)
PENNZOIL PLATINUM - HPZ-37 (silver can)
PENNZOIL PLATINUM - P0-37 (white can)
HONDA OEM - 15400-PLM-A01 (Filtech - Toyo Roki)
HONDA OEM - 15400-PLM-A02 (Honeywell - Fram)
NPN - 1640719
HKS - 52009-AK001
MUGEN - 15400-XL5B-000 (Gold can)
GREDDY - 0X-05
MIGHTY - M4455
QUAKER STATE - QS14612
VALVOLINE - VO39
CHAMP - PH2808
CASITE - CF402
GROUP 7 (By Purolator) - V4612
HASTINGS - LF386, LF402
MANN FILTER - ML1002 (German Made)
MAHLE - OC330
BECK/ARNLEY - 041-8163
FEDERATED FILTERS - LF402
MAGNETTI MARELLI - 1AMFL00003 (offered by mopar)
HENGST - H90W25
PRONTO - PO4459, PO4476
FULL FILTER - 1-OHD331
SCT GERMANY - SM104 , SM121 , SM124
MOTOMASTER - 17-1723-6
CHAMPION - PH2808
DONALDSON - P550162
AMSOIL - EA15K20
LENO LJ-1687
PROMOTIVE - PH4612 (by Purolator - for commercial use)
HAVOLINE - TFC-538
Please add to list.
thanks
WIX - 51334
DENSO - 150-1006
MOTORCRAFT - FL-810
CARQUEST - 85334
STP - S2808
NPN - 1640719
HKS - 52009-AK001
GREDDY - 0X-05
MIGHTY - M4455
VALVOLINE - VO39
CHAMP - PH2808
CASITE - CF402
MAHLE - OC330
HENGST - H90W25
CHAMPION - PH2808
DONALDSON - P550162
AMSOIL - EA15K20
LENO LJ-1687
HAVOLINE - TFC-538
Nice list dude! Didn't know Mugen still made an oil filter. Will have to pick one up for my next change.
