CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS?
Old 03-16-2006, 03:51 PM
B18ceed's Avatar
Default CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS?
I BUMPED MY BATTERY INTO THE FIREWALL AND EVER SINCE THE CAR HAS EXTREMELY WEAK SPARK AND WONT TURN OVER. IVE GONE THREW 2 IGNITION COILS AND ONLY ONE WORKED FOR ABOUT 20MINUTES AND THEN WENT OUT?PLZ HELP
Old 03-16-2006, 08:18 PM
yellowrexsi's Avatar
Default Re: CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS? (B18ceed)
Check the ignition fuse under the hood and make sure its not blown.
Old 03-17-2006, 07:22 AM
B18ceed's Avatar
Default Re: CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS? (yellowrexsi)
it looks good man, any other suggestions?
Old 03-17-2006, 07:39 AM
DC2 Mang's Avatar
you probably have a bad connection, check all wires that run to the starter, alternatop and any ground wires running from the battery
Old 03-18-2006, 04:41 PM
B18ceed's Avatar
Default Re: CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS? (JDMdc2lsVtec)
does the ignition module control spark?
Ek9Max
Honda S2000
11-02-2009 07:35 AM
Hanmin
03-31-2009 07:11 AM
driter
06-12-2008 04:40 PM
chazsi
04-20-2007 11:43 AM
flip1199
12-12-2006 12:24 PM
Quick Reply: CAN A BAD ALTERNATOR CAUSE WEAK SPARK AND SHORT OUT IGNITION COILS?
