what pigtail connector for walbro fuel pump?
Re: what pigtail connector for walbro fuel pump?
I'm actually searching for this right now, still.
I've searched '2192' (stamped at the pump side of the connector) and spent an hour searching the internet and making calls.
Looks like some hondas have that connector from factory. My 92 GSR does not. Anyone know where I can find this thing?
If its a walbro 450 for ethanol fuel there is a special plug that walbro doesn't sell. Ill look when I get home for the place that sell them. There I expensive and comes withe pins as well.
Ok here is the link for the walbro 450 connector, comes with the pins and seals etc.
http://www.bmotorsports.com/shop/pro...19j1o954ucppc6
Or you can dig through Waytek they have them cheaper.
http://www.summitracing.com/parts/vpn-94-615
But I can't figure out if this is going to be the right connector or what.
By OEM, is rudebwoy implying OEM Honda/Acura fuel pump connector, for a different car? Like a 94 GSR or something? I could try to find one of those if this Walbro one isn't correct... But my 92 GSR's OEM wiring is not clearly connecting to the Walbro.
Edit: This is a comparison between my OEM pump connection situation (two wires that are tightened down with a nut, each, on my stock fuel pump VS a connector harness needing to be plugged into the Walbro) http://www.imgur.com/FzcqkEw.jpeg
SiRCiviC94
11-28-2011 01:20 PM
Boricuanology
09-20-2006 04:43 PM
