D16A motor
Old 10-21-2012, 08:05 AM
  #26
ugadawg187's Avatar
Default Re: D16A motor
I got a jdm d16a stamped on the block. it was a short block motor so i swapped everything over from my y8. I took the valve cover off & it looks like a y7 head but it has ports for the vtec solenoid & stamped pj2-5 04. These motors are so confusing.
ugadawg187 is offline
Old 10-29-2012, 08:50 PM
  #27
BigBunnyBoi's Avatar
Originally Posted by martyr1391
Hi, I was looking to find information on a JDM D16A ... there ain't much out there, except that eveyone thinks that the D16A "JDM" is really an older 88-91 USDM Civic motor with 92-106 HP. I think Honda just recycled engine codes.
I am looking for information since I just bought a late model JDM D16A and I wanted a D16Z6 and my JDM importer shipped the D16A instead. (yes, I know there was never a JDM D16Z6). Anyway.. I was worried that HP will be too low or too high for that matter. All the auto-crossing organizers like SCCA and track clubs here in the northeast want me to have a stock motor to run Street Touring. Sucks to be me now that I have the JDM D16A. Before I go ape **** on the JDM importer that he promised one thing and I got the other... I decided to do some homework.
I found these links that might help:
http://www.geocities.com/Motor....html
The late model D16A engine is off '95 or '97 EK5 or '96-'97 EK8.
http://www.alljapanesecars.com...=1997
The EK5 was rated at 120 HP and EK8 at 105 HP. Regardless of the year or model, D16A has the same stroke and bore as a D16Z6, but the D16A has a 9.4 comp ratio where the Z6 is 9.2.
http://www.cars-directory.net/...2498/
I noticed that years stated that the D16A was available is different between the last sites. Anyway... I assume that the horsepower is different because of LEV requirements. The big question remains what is really different between the two motors.
1) The P32 intake...
okay what else??? I have no idea. JDM HONDA-TECH GODS PLEASE HELP!!!
Modified by martyr1391 at 1:35 PM 12/19/2005
Modified by martyr1391 at 1:36 PM 12/19/2005
There is D16Z6 engine found in Honda City Type Z.
We have plenty of those here in the Philippines.
BigBunnyBoi is offline
Old 01-27-2013, 09:06 PM
  #28
HamzaZ's Tuning's Avatar
I have a d16a swapped in my ej6 sedan
HamzaZ's Tuning is offline
Old 03-15-2013, 02:17 PM
  #29
martyr1391's Avatar
The JDM D16A (SOHC) is the same as an USDM D16Z6 (SOHC). I found references that the cam in the D16A has slightly more aggressive ramp, but the same lift, hence the 2 hp difference.
martyr1391 is offline
Old 05-18-2014, 03:26 PM
  #30
jfible's Avatar
I just bought a 93 honda civic hatchback. Well the kid sold me it told me it was d16z6 vtec an The valve cover just says honda n doesn't say vtec no big deal. I looked an saw the vtec solenoid so I was like ok it's the vtec ok and it's pretty quick little engine. But I went to do a tune up am my spark plug threads broke off in the head so I bought a used d16z6 head an took the valve cover off of it an seen they look different from eachother. Everything is the same except the head from the car the d16a head did not have a lost motion assembly holder. The new head off the d16z6 did have one so someone told me the d16a wasn't vtec but it had the solenoid on the head an was hooked up an the car was alot fast than my 96 coupe d16 non vtec. So I don't know if it was vtec or not I thought it was. But will the d16z6 head fit on the block from the d16a?? The head bolts are same thread size but they are different lengths. The bolts from the d16a are about 4 or 5 inches long an the z6 bolts are about 6 inches long. But same thread size. Will the z6 head fit on that block?? An why wasn't there a lost motion rail on the d16a?? Help me out please
jfible is offline
Old 05-18-2014, 11:04 PM
  #31
Nave43's Avatar
I have a 93 Del sol Si with D16A SOHC Vtec the swap was done by the previous owner so i Am not sure were it came from, but i do know its a bitch to find any information on. Its actually stamped D16A on the block... All i can find its its JDM, and to my understanding the same as a D16Z6 just with more torque. Please correct me if i am wrong.
Nave43 is offline
Old 05-26-2014, 09:41 AM
  #32
jfible's Avatar
jfible is offline
Old 05-26-2014, 09:52 AM
  #33
jfible's Avatar
Hey Nave43 I just read your post man and no one else is writing me back on here.. but I bought a 93 hatch few months back an had to change the head on it due to spark plug broke off inside. Well when I bought the car the guy told me it was a d16z6 vtec an dumb me didn't look at the block at all and look for the stamp. I test drove it am looked at everything just about under the hood but the stamp cuz I seen the vtec solenoid so I figured it was vtec. When driving the car it was pretty quick like a z6 vtec so didn't have any reason to not believe him. Well I'm not replacing the head found a used d16z6 head and dizzy an starter an when I got to tearing it apart to clean it out an rebuild the head I noticed this rail that's on top of the cam and sits above the springs an valves inside the head well the other head the d16a head that came off the car didn't have the rail thing. Which is called a lost motion assembly rail.. so got to wondering why. And people have said if it's vtec it has to have the lost motion rail so if the d16a head had a vtec solenoid an it was hooked up an seemed to be functional but didn't have the rail it was not vtec.. is there anyway because it's a jdm engine an different countries do **** different they just didn't out it on this engine or what?? And will this d16z6 head work on the d16a block even if it wasn't vtec? If you have your valve cover off see if your d16a head has this rail I'm talking about. Lost motion assembly rail. Thanks man please write back or anyone else help me figure this weird **** out lol. Thanks guys
jfible is offline
Old 05-28-2014, 10:13 PM
  #34
Nave43's Avatar
The best i can do for you is look for it whenever i tear it down to paint the valve cover. What does the head from the D16A look like?
Attachment 366897
If you cant see in this picture i will go out in the morning and take a close up, and check its year
Also there is a number somewhere on the head that identifies the year it was cast, that also may help I.D. its origin.
Did the Vtec work while the D16A head was on the motor?
Maybe the old head was from a non Vtec motor?
Nave43 is offline
Old 05-29-2014, 11:26 AM
  #35
Nave43's Avatar
Sorry to double post but cant ad pics via edit...
Name:  d16 aaaaaaa.jpg
Name:  d16 aaaaaaa (1).jpg
Name:  d16 aaaaaaa (2).jpg
Nave43 is offline
Old 06-01-2014, 06:52 AM
  #36
HiProfile's Avatar
The LMA assembly isn't exactly what makes it vtec or not, it's the CAM and ROCKERS. If there are 5 lobes per cylinder and half a rocker between each intake rocker, it's sohc vtec.
It's possible to have the solenoid but not have vtec internals if the previous owner swapped in all d16y7 [or equivalent] components. The 96+ vtec [single stage] and non-vtec are virtually the same casting, except the vtec casting has provisions for a vtec solenoid. Below is a thread that shows the parts list to convert from vtec to non-vtec [bottom of 1st page]:
http://www.d-series.org/forums/n00b-...8-mini-me.html
HiProfile is offline
Old 07-17-2019, 02:17 PM
  #37
Axelsevilla200's Avatar
Originally Posted by 9c0rxsi
I have a bought 98ex with a bad d16y7. I ordered a d16y8 and they sent my a d16a i went ahead and had him put it in after having to switch the intake mani for wiring. The motor runs great until 5500 rpms and then sounds like its hiting a rex limiter. Any suggestions.
I have a 2000 civic ex coupe, had a d16y8 but it spun a bearing so i ordered a jdm d16A and it was a complete bolt on swap. used the same intake manifold and wiring everything was the exact same, but i also had that problem with it not really liking the 5500rmp range, it was probably because i was using the injectors that came with the d16A engine. i swapped the injectors out for the ones that were on my d16y8 engine and she rips now, also noticed that the vtec hits a lot harder than the vtec from a d16y8
Axelsevilla200 is offline
si_lee
33
10-13-2009 05:10 PM
b16nonoy
04-22-2007 10:06 PM
JDMroyEG5turbo
01-16-2006 08:32 AM
metal-x
01-16-2002 06:45 AM
Quick Reply: D16A motor
