HOW TO:Balance Shaft Removal
Old 09-05-2006, 05:15 PM
  #26
M2B4's Avatar
Default Re: (SB tuning)
may sound noobish but do you feel any more vibration with the balance shaft off?
Old 09-05-2006, 06:02 PM
  #27
high_revs's Avatar
people say you do.....when i took mine off, this was back when i had a h23 in a prelude, i could feel it vibrate any more then when the belt was on.
Old 09-05-2006, 10:49 PM
  #28
Televator's Avatar
Default Re: Balance Shaft Removal::HOW TO!! (djbrandonr)
This is definetly something I will do after I tear down my car. It's been a while after the robbery and I think this is a good way start. Thanks for posting this. For some reason I'm really looking forward to doing this more that all the other things I've read in the DIY threads.
Maybe you made it look easy... I guess I'll find out.
Old 09-05-2006, 11:01 PM
  #29
MadCityLude
Guest
Posts: n/a
Default Re: Balance Shaft Removal::HOW TO!! (Televator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">may sound noobish but do you feel any more vibration with the balance shaft off?</TD></TR></TABLE>
If your running aftermarket mounts, or inserts to stiffen the mounts, you will definatelly feel more vibration. It isn't really all that bad though. I didn't mind it, but I am also running DIY inserts in my mounts, no PS, no cruise, no AC, and no cat.
So by the time you get used to all that the little vibration you feel is really nothing. And anyway if your doing this to your engine it is for performance. I certainly don't mind giving up a little comfort for a few ponies. If you do then I wouldn't recomend it.
Old 09-05-2006, 11:02 PM
  #30
moderator emeritus
98vtec's Avatar
Default Re: Balance Shaft Removal::HOW TO!! (MadCityLude)
i didnt feel any vibration difference from stock when i put in the ES inserts. I haven't removed my BS belt yet, however i plan to do that soon.
Old 09-05-2006, 11:05 PM
  #31
MadCityLude
Guest
Posts: n/a
Default Re: Balance Shaft Removal::HOW TO!! (98vtec)
I did the DIY polyfill mounts, and the balance belt removal at the same time so I increased the vibration, and decreased my mounts ability to dampen it at the same time.
Old 02-22-2007, 02:57 PM
  #32
Go Tigers!
Bense's Avatar
is it required to remove the crank?
seems like i could remove just one of those main caps to tap the thread in the block and be careful to where the shavings land.
Old 02-22-2007, 05:19 PM
  #33
577HondaPrelude's Avatar
Default Re: Balance Shaft Removal::HOW TO!! (Bense)
I'm too lazy to pull the motor out just to remove the shafts, so I did the ghetto method to stop the shafts from rotating... I cut the belt.
if or when I need a motor rebuild I plan to remove the shafts and use this kit.
Old 02-23-2007, 09:21 AM
  #34
rawNArsxS's Avatar
Default Re: Balance Shaft Removal::HOW TO!! (577HondaPrelude)
do the shafts have their own individual belts, do they share the same belt, or do they share a belt with anythin else that would require a smaller replacement belt(kinda like having to get a smaller belt if u take off the ac or ps)?
Old 02-23-2007, 09:54 AM
  #35
budget's Avatar
Default Re: (Hawkze_2.3)
did this about 3 years ago to lazy to do a write up though
Old 02-23-2007, 09:57 AM
  #36
rawNArsxS's Avatar
Default Re: (budget)
after reading this one and then reading the one in the prelude faq i think this one is much better than the one hondaddict did. i think this one should replace his in the faq
Old 02-23-2007, 01:48 PM
  #37
Default Re: (rawNAprelude)
the balancer shafts (2 in total) are on a single belt that drives them both. This belt drives nothing else on the car.
Old 02-23-2007, 02:44 PM
  #38
rawNArsxS's Avatar
Default Re: (577HondaPrelude)
good to go, thanks man
Old 03-04-2007, 09:09 PM
  #39
kornerk12's Avatar
Default Re: Balance Shaft Removal::HOW TO!! (Chris F)
Which hole do you ream out im not 100% sure from your description. I understand what you are doing just dont know which hole you did it to. And what are u really doing by pressing out those dowels ? Sry for the noob questions.
Old 03-05-2007, 11:10 AM
  #40
djbrandonr's Avatar
Default Re: Balance Shaft Removal::HOW TO!! (kornerk12)
its the rear middle hole, the only one that a drill bit that size will fit..IIRC. Plugging the dowels in the girdle is pluggin specific oil passages that lead to the BS areas.
Old 03-15-2007, 12:56 PM
  #41
2Point3's Avatar
Default Re: (M2B4)
where can i buy the balance shaft removal kit and What is the purpose of removing it, im kinda of new to this stuff thanks for all the help.
Old 03-15-2007, 01:09 PM
  #42
Ludster's Avatar
http://www.kaizenspeed.com/det...50&NM=
Old 03-16-2007, 01:46 PM
  #43
2Point3's Avatar
Default Re: (M2B4)
sorry guys but this is kinda off topic. Im going to be putting and h22a head on a h23 block which tensioner should i use. Im also gonna slap on a turbo kit, is it safe to remove the balance shafts....... THANKS IN ADVANCE
Old 03-16-2007, 02:18 PM
  #44
rawNArsxS's Avatar
Default Re: (2Point3)
h23 block already has the manual tensioner y would u change?
Old 03-18-2008, 03:43 PM
  #45
BIG T's Avatar
Default Re: (high_revs)
Lastly we need to block an oil passage in the block that runs to one of the shafts??
just wondering if someone could tell what the reason blocking off this oil passage is for??
can you leave and not have any problems??
Old 04-01-2008, 03:57 PM
  #46
hondamark35's Avatar
Default Re: (BIG T)
my understanding is that you would have low oil pressure if you don't plug the passageways.
think of it like having your thumb over the end of a garden hose, you've got higher pressure in the hose and coming from the hose past the small opening created by your thumb. then when you move your thumb out of the way the pressure in the hose drops.
it's the same in your engine. pull the shaft journal out of the way of the bearing and oil passageway, and you loose pressure.
on another note- FYI if you will... shafts, pulleys, rear gear housing, everything removed only weighed 9lbs all together (came out of and F23A1). i've seen ten, which i believe, but i've also seen 15, and 22 (somewhere in this thread). enjoy.
Old 04-01-2008, 07:07 PM
  #47
AdReNaLiN's Avatar
Do you have to pull the motor out to remove the balance shafts?
Old 04-02-2008, 06:50 AM
  #48
flyrod's Avatar
Default Re: (AdReNaLiN)
Yes, or cut holes in the uni-body to slide them out the side. Could drop the engine down enough to do it without technically removing it. I guess you could also slide the shafts out as far as possible, cut of the ends, slide them out a bit more, cut them off, etc.
Old 10-08-2011, 08:27 PM
  #49
Tiago_dux's Avatar
Default Re: HOW TO:Balance Shaft Removal
do we have to remove the crank??
thanks
Old 10-09-2011, 07:05 AM
  #50
flyrod's Avatar
If you take the main bearing caps off there won't be much holding it in...
Quick Reply: HOW TO:Balance Shaft Removal
