THE OFFICIAL 4th Generation Prelude Auto To Manual Swap Thread
#26
Re: (pprowler6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pprowler6 »</TD></TR><TR><TD CLASS="quote">i did this about a year ago...i didnt do any of those wires expect for reverse lights and i jumped the two wires on the big brown clip so i wouldnt need the sensor on the clutch pedal. sorry its a little vague pm me if u have questions.</TD></TR></TABLE>
Does your cruise control work?
#28
Re: (bboixtc)
the wiring goes has follows, take the 2 wires from the clutch switch that is "closed" when the clutch is completely depressed, and take both of those wires to the big brown connector by the shifter and insert both wires into the brown connector. it does not matter which wire goes where as long as both are in the connector, i attached a picture to help
Modified by h23prelude at 9:05 PM 3/6/2008
#29
oh, and i have a sparco steering wheel so i didnt bother with my cruise control, sorry but i cant reall help you with that part, and yes most of those bolts from the f22 should work, but don't quote me on that.
good luck
good luck
#31
according to the part numbers from Majestic honda, they are the same. i would give it a try if you found one at a junk yard they probably wont charge you more than 15 dollars, otherwise theres usually some on ebay. good luck
#32
Re: (h23prelude)
You've been extremely helpful. I really hope everything will go smoothly. During my spring break is when I'll be doing the swap. F22 tranny to the h23.
I'll have to change both of my axles right? not just the Driver side? And h23 axles will go into the f22 tranny right? Are all the axles interchangeable? I just wanted to know so I don't waste any money.
Is there anything else I should buy or have extra before I do this?
I'm about to get the clutch master and slave cylinder from autozone.
#33
well when i did my swap i mated a M2S4 5-speed to my H23 (M2S4 is the stock H23 5-speed transmission) and i kept the passenger side C/V axle, it was the same no matter if the car was an automatic or manual.
in your case you are mating a f22a1 5-speed (P2U5) to the H23 block. im about 95% sure that you can keep your automatic passenger side C/V axle i would try fitting it first because usually they are the same. but i could be wrong simply because i have not dont this exact swap.
BTW if you need any specific pictures of any parts let me know its no problem
Modified by h23prelude at 5:48 PM 3/7/2008
#35
yes, you have the wiring right, but you need to wire it to the other brown plug, the one attached to the cars wiring not the automatic shifter brown plug, because that whole automatic shifter assy. will be removed.
and the grey connector is only used to wire the reverse lights, you take the reverse switch on the transmission and wire to the wires on that plug. i cannot tell you exactly how to wire that, because its the only thing i havent done yet, but im gonna do it this weekend or the next, so ill be able to tell you soon
Modified by h23prelude at 6:31 PM 3/7/2008
#37
Re: (h23prelude)
-REVERSE LIGHT WIRING 4TH GEN-
find the grey plug that was attached to the automatic shifter slide switch
find both the yellow and green w/black stripe wire
cut them and connect, turn on ignition to "run", go look if your reverse lights are on. if so
find 2 new wires to run from the yellow and green w/black stripe wires (originally from the grey plug) to the two wires attached to the reverse switch mounted on top of the transmission near the shifter levers.
note: polarity does not matter, the two wires can be attached to the reverse switch either way and still work.
pics of the yellow and green w/black stripe wires EDIT: i'm a moron and i took a picture cutting the green with white stripe wire, you need to cut the wire to the right of the yellow wire, which is green with a black stripe, sorry
attach 2 new wires to run to the reverse switch
locate your reverse input switch on the top of the transmission, attach the 2 blue wires shown above to the reverse input switch. all done!
#38
yea, you got your clutch wiring correct, and above i show how to do the reverse lights wiring, just remember to have about 8-10 feet of wiring laying around to use
#39
Re: (h23prelude)
More questions:
Will the VSS work from my auto tranny on the f22 manual tranny?
Where did you run those wires for the reverse lights? (which hole)
Did you pull out your motor when you did this? I'm asking because after pulling the clutch lines from the parts car, I saw that they're really deep in the firewall.
Also are the clutch lines the same from the f22 and h23/h22?
What's everyones opinion on this clutch and flywheel combo? Since I'm on a budget and this is my daily driver.
http://cgi.ebay.com/ebaymotors...84405
Modified by bboixtc at 8:15 AM 3/10/2008
Modified by bboixtc at 10:15 AM 3/10/2008
#40
I had my engine out when I did this, the clutch lines should interchange.
I ran the reverse lights through where the heater control valve cable comes through.
I tend to stay away from ebay products in places like clutches and flywheels, they're crucial to operation, and hard to replace if they mess up. You should check the clutch poll threads from the past and see if anyone has been ok with that clutch. The flywheel will probably be just fine.
I'm not sure on the vss, but I have to assume not.
#41
Re: (mgags7)
can anyone confirm that the vss aren't the same from manual and auto? rather, that it won't work, I checked the part numbers and they are off by 1 digit. one ending in 51 the other in 50.
Modified by bboixtc at 11:21 PM 3/10/2008
#42
Re: (bboixtc)
anyone?
what about this:
eh, i just bought the fidanza 8lb and exedy oem clutch
anyone recommend a certain place to get the clutch master and slave cyl? or are they the same wherever I buy it? how about this:
http://cgi.ebay.com/ebaymotors...ZWD1V
Modified by bboixtc at 11:51 AM 3/11/2008
what about this:
#45
It is most likely the same crap you get on eBay.
Its up to you. I'd spend the $100 and go OEM to save the potential headache.
Most autozone stuff comes with a warranty, so at least if it fails, all you have to do is the work.
#46
Re: (mgags7)
So here are things I still need to get:
Driverside ABS axle
clutch master and slave cylinders
New bolts for intermediate shaft?
OEM throwout bearing
rear main seal?
axle seal
tranny fluid
brake fluid (for clutch line)
Hondabond? needed?
type sh shift boot
anyone wanna add stuff to the list that please do so.
BUMP FOR ANSWERS ABOUT THE VSS
Driverside ABS axle
rear main seal?
axle seal
tranny fluid
Hondabond? needed?
type sh shift boot
