> Honda Accord (1990 - 2002)
Old 10-24-2005, 04:27 AM   #1
jdoz22
jdoz22's Avatar
Send a message via AIM to jdoz22
Default Programming remote entry keyfob / 2003 Accord EX
Does anyone have a procedure, or can point me to a procedure, for re-programming the keyfob on a 2003 Accord EX? I'd like to save a 2-hour trip to the Dealership if possible, and it is not in the manual.
Thanks
jdoz22 is offline   Reply With Quote
Old 10-24-2005, 08:27 AM   #2
JimBlake
JimBlake's Avatar
Default Re: Programming remote entry keyfob / 2003 Accord EX (jdoz22)
This is for '98 & '99, but I think it's the same.
1) Unlock Doors
2) Turn ignition key to "ON" position (II)
3) Press the "LOCK" or "UNLOCK" button on the remote
4) Turn the ignition key to the "OFF" position (0, I)
5) Turn the ignition key to the "ON" position
6) Press lock or unlock
7) Turn key to off position
8) on position
9) lock or unlock
10) off position
11) on position
12)lock or unlock - doors should cycle to indicate successful programming. If you only have one remote, turn ignition to off or don't touch anything. if you have 2+ remotes, go to 13:
13) lock on each transmitter that you need to program
*Steps 2-12 must be performed within 5 seconds of each other. Step 13 can be performed within 10 seconds of step 12.
JimBlake
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
TECHNICAL(?) quote...
Originally Posted by ??
some guy told me that I could set the torque wrench that I have to 100 ft/lbs and then torque it, when it clicks torque it again at 81/ft lbs to have the torque add up to 181 ft/lbs
JimBlake is offline   Reply With Quote
Old 10-27-2005, 11:38 AM   #3
jdoz22
jdoz22's Avatar
Default Re: Programming remote entry keyfob / 2003 Accord EX (JimBlake)
Thank you so much, it worked like a charm on my 2003 Accord EX.
My warranty is up in a few days, hopefully this vehicle will last a long time
06, 2003, accord, doors, entry, fob, ignition, key, keyless, problems, program, programming, register, remote, unlock
