how come my accord shakes when i shift gear????
Old 09-28-2005, 07:52 PM
jli18's Avatar
Default how come my accord shakes when i shift gear????
i have a 96 accord. when i shift gear at 3k rpm or above, the car shake . and it feels like someone hit you from behind.. why is it like that?? is that because the flywheel is no good... plz help
Old 09-29-2005, 12:03 AM
Charri's Avatar
Default Re: how come my accord shakes when i shift gear???? (jli18)
I'm assuming its stick since you said fly wheel and not torque convertor. I believe your clutch is starting to wear out and is starting to slip.
Old 09-29-2005, 05:50 AM
typhoon's Avatar
Is it almost a bouncy feel to the car, just after you release your clutch?
Old 09-29-2005, 07:32 AM
madd's Avatar
Default Re: how come my accord shakes when i shift gear???? (typhoon)
not to hijack the thread, but i see now point in creating a new one... my 5th gen auto will shake when shifting up at a certain point. somewhere between 50 and 60 mph. it will shudder pretty bad, but if you lightly press the gas it goes awat. when i let off the gas to let the car slow down by itself (lets so at 60), the car has a horrible time shifting. every downshift is jerky, etc... ideas? it's most likely the tranny seeing as it has 220k on it, but theres a small part of me hoping its something else!
Old 09-29-2005, 07:36 AM
stillrockin18s's Avatar
Could also be a tranny mount going bad.
Old 09-29-2005, 09:33 AM
jokestar's Avatar
couldnt it be a motor mount as well?
Old 09-29-2005, 10:39 AM
Default Re: (jokestar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jokestar &raquo;</TD></TR><TR><TD CLASS="quote">couldnt it be a motor mount as well?</TD></TR></TABLE>
Yeah, it could be. I would start by checking all your mounts.
Old 09-29-2005, 11:07 PM
jli18's Avatar
Default Re: (lowriden_acura)
i just had my clutch replaces during the summer so it shouldn be the clutch
it shakes real bad if i release the clutch fast, i can even hear the sound from the suspension or something. but if i release it slowly, it will grind
i guess its the engine or tranny mount. do u guys kno where to get it done and how much would it cost
Old 09-30-2005, 07:47 AM
projectTeG's Avatar
start checking axles too i just fixed the problem with my car because i had a passenger side axle that was binding due to the inner joint being to long
tonyle789
05-27-2013 08:07 PM
loxienouis
01-06-2011 01:09 PM
anita33
02-07-2009 04:07 AM
vtec fan
09-13-2003 11:08 AM
Quick Reply: how come my accord shakes when i shift gear????
