b16 cams on D16A8?
b16 cams on D16A8?
if you read my previous topic you know that i just swapped in the D16A8 which apparently is equivalent to the JDM ZC motor but is an EDM motor...now i know that they're different series but would it be possible to put a couple of cams and cam gears into that D16 given that it is a dual cam?
1 Post
Re: b16 cams on D16A8? (ramirocka)
B and d series cams are not interchangeable, especally not vtec cams in place of non vtec cams, there are company's that sell cams for the zc - "search"
u got that backwards u can use b16 cams gaers but its off by a tooth,ull have to recount it start at the nocth where the key goes and reocunt it then reecth the timing mark.u can use a pucnh to do that or just scratch it in the gear.if u want cames go to ebay,sometimes zcresource.com has group buys u can get them cheap as hell then.but as for the cam gears people make them for the dual cam zc like hks,<<<which are hard to find.je makes some so do few other people.one word for u SEARCH!!!!!!!!!!!!!!!!!!!!!
