how do i siphon gas
Old 08-28-2005, 06:35 PM
folta2169's Avatar
Default how do i siphon gas
i need to siphon the gas out of my 96 cavalier and my buddies prelude and neon. I have the problem of the hose not going down into the gas. It either isn't long enouph or it just stops and wont go any further into the tank.
Old 08-28-2005, 06:38 PM
upgraded's Avatar
find the fuel return line and pull it off and run a hose from it into a gas container. should be attatched to the feul pressure reg or near. hope that helps.
Old 08-28-2005, 06:43 PM
folta2169's Avatar
Default Re: (upgraded)
i want to do it the old way and use a hose and little siphon hand pump thing.
Old 08-28-2005, 06:51 PM
siregcivic's Avatar
uhh... you cant siphon gas on newer cars as i believe.. they have some kinda valve in em ... im not shure.. but when i tried siphoning gas outta my car when i wrecked it with a full tank.. i had to buy this little *** hose and use that.. that **** sucked soo much.. it took like 2 hours to siphon 11 gallons
Old 08-28-2005, 07:11 PM
upgraded's Avatar
Default Re: (folta2169)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by folta2169 &raquo;</TD></TR><TR><TD CLASS="quote">i want to do it the old way and use a hose and little siphon hand pump thing.</TD></TR></TABLE> Why not let the fp do all the work? Just a suggestion.
Old 08-28-2005, 07:12 PM
rob...'s Avatar
suck it into your mouth and spit it into a new container.
no j/k autozone sells a kit to do it
Old 08-28-2005, 07:16 PM
TurboFart's Avatar
Default Re: (baseballinmyass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by folta2169 &raquo;</TD></TR><TR><TD CLASS="quote">i want to do it the old way and use a hose and little siphon hand pump thing.</TD></TR></TABLE> i agree gas prices are rather high, but thats kinda jewish bro.
Old 08-28-2005, 07:35 PM
Kamin's Avatar
Default Re: (TurboFart)
newer cars have a screen in the filler neck that wont allow siphoning.
buy your own gas
Old 08-28-2005, 07:37 PM
midwesta's Avatar
drain it out at the bottom of the tank, hondas have bolts.
ThatsMyEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baseballinmyass &raquo;</TD></TR><TR><TD CLASS="quote">suck it into your mouth and spit it into a new container.
no j/k autozone sells a kit to do it</TD></TR></TABLE>
my ghetto *** company trys to make me do this. you have to shove a hose down the tank, then blow really hard and then push the hose down into a tank it works. just dont get it in your mouth.
v8killaz
Welding / Fabrication
09-08-2014 10:02 PM
jdmcoupeEJ1
18
01-11-2008 05:40 PM
RS'R'
03-31-2007 07:40 PM
Frozen E
01-24-2005 05:39 PM
Layziebtnh055
10-20-2004 08:37 PM
Quick Reply: how do i siphon gas
