My car shimmies and shakes like hell when I brake.
Old 02-22-2002, 07:54 AM
4doorRS5spd's Avatar
Default My car shimmies and shakes like hell when I brake.
Well, when I brake, going anywhere from 55-80 mph, the car will shimmy and the steering wheel will shake badly. Anything under 50 mph, the car feels fine. I have some abnormal tire wear, due to the fact that I have not had an alignment for three years, but it is really not that bad. For the brakes, I have stock Accord rotors up front with stock pads, and there is still a lot of pad left. For the rear, I have the stock POS drums with some cheap Rebestos pads. They are relatively new. I am thinking that maybe my rotors are warped and need to be turned. Is there a way to tell visibly if the rotors are warped? What can be causing the shimmy? Thanks.
Old 02-22-2002, 08:27 AM
rtype11's Avatar
Default Re: My car shimmies and shakes like hell when I brake. (accord55)
brake job, you may have a seized caliper, drum etc.....
Old 02-22-2002, 08:30 AM
Spencer's Avatar
I would bet the farm that your rotors are warped up front. You can't see the warping, but my 94 Prelude had a similar but less pronounced problem. I figured the rotors were shot so I just replaced the rotors. I would suggest at the least getting them resurfaced or examined. The tech will recommend a replacement or a resurfacing based on how bad it is.
Just one of those sucky things. Don't let it get'cha down.
Good luck,
Spen
Old 02-22-2002, 10:04 AM
bps2799's Avatar
New tires, alignment, check rotors for warpage -- turn if warped, non-directional scuff if not warped.
Drums are not the issue since they hardly do anything.
Old 02-22-2002, 12:53 PM
Urban Business
Guest
Posts: n/a
Default Re: My car shimmies and shakes like hell when I brake. (bps2799)
check your wheel weights as well. you lose one usually thing shakes a lot at high speeds then like a **** when you break. or just shakes when you break
Old 02-22-2002, 02:58 PM
flymecourageously's Avatar
check your wheel lug nuts for even torque on all four lugs each wheel if not your tires need to be balanced .when was the last time you had your brakes done?could be rotors need to be turned
Old 02-22-2002, 07:20 PM
Default Re: My car shimmies and shakes like hell when I brake. (flymecourageously)
I appreciate all the info
Old 02-23-2002, 01:39 PM
Kamin's Avatar
my rotors ar warped like a **** and it does the same thing
anything ove 50mph and the steeringwhele starts to shake
oh boy at the track hah the whole dash shakes
im holding out to get a set of bremobs
Old 02-25-2002, 07:39 AM
bps2799's Avatar
Default Re: My car shimmies and shakes like hell when I brake. (redteggy)
Make sure you bed your pads in too.
Drive first 100 miles w/o hard braking.
Then, 8-10 - 50-10MPH stops OR 70 - 40MPH stops.
Do the brakes SMELL? Good. Do they sound bad. Okay.
DRIVE (do not stop completely) for 15 minutes, staying off the brakes (add an extra 5-10 minutes if you do.)
IF you must stop, stop early so you can roll the car forward to turn the rotors. Get back moving ASAP.
Repeat process above, then put the car away ASAP after your cool down period and let the rotors "cure."
This is all worthless if you have shitty tires, bad alignment, and out of balance rims. Pissing money down the drain.
Old 02-25-2002, 08:13 AM
Crazydave's Avatar
READ THIS about Warped Rotors http://www.stoptech.com/whitepapers/...otors_myth.htm
yes turning rotors may get rid of the symtoms but it may keep coming back..
405hp
Honda Civic (2006 - 2015)
14
11-02-2009 05:14 AM
poppypizza
04-18-2007 08:52 PM
teggsr925
03-03-2007 01:35 PM
WalkerGSR1
Suspension & Brakes
08-13-2006 02:36 PM
jorge99hx
25
12-10-2005 12:52 PM
Quick Reply: My car shimmies and shakes like hell when I brake.
