The official auto to manual ECU conversion thread
Old 06-11-2005, 01:53 PM
lunarcry's Avatar
Default The official auto to manual ECU conversion thread
First I want to thank Jim Truett for his write-up on this conversion which help me a lot and also I want to thank the members of Honda-tech (Prelude forum) for always keeping it real. This write up is more so you know what is involved and what you are getting yourself into.
Auto to manual ECU conversion;
1. Disconnect the battery Pos terminal first and then neg.
2. Locate the Ecu, Passenger side underneath the rug.
3. The Ecu is on the inside of a protective cover, which have 4 10mm nuts holding it in place; you will need a 10mm deep socket to free the Ecu.
4. Remove the harness.
5. Unbolt the Ecu from its protective cover.
6. Remove the lit from both side of the Ecu.
7. Locate the 000 resistor that is label RP13.
8. In addition, locate the target area RP14 on the other side of the circuit board.
9. Very carefully de-solder the resistor use a precision 1.0 mm flat screwdriver to carefully pry the resistor from the board (careful do not break the resistor) remember time is your friend do not rush take your time.
10. After successfully removing the 000 resistor from RP13 go ahead and place it on the position RP14
11. Solder both end of the resistor.
12. Screw every thing back into place in the reverse order of removal.
13. Plug the Ecu and then plug the battery.
14. Turn the car on and the cell will be gone.
As you can see the cell was gone and the OBD2 scaner did not pick anything at all.
once again thank Jim Truett.
Old 06-11-2005, 02:42 PM
Digga4's Avatar
Default Re: The official auto to manual ECU conversion thread (lunarcry)
not to sound like a moron but just to make sure I am understanding this.... I can take my JDM auto ecu and convert it to 5 spd with this method correct?
I have been asking this question here local, but know seemed to know the answer....
Old 06-11-2005, 03:11 PM
lunarcry's Avatar
Default Re: The official auto to manual ECU conversion thread (Digga4)
you could try
Old 06-11-2005, 03:48 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Digga4 &raquo;</TD></TR><TR><TD CLASS="quote">not to sound like a moron but just to make sure I am understanding this.... I can take my JDM auto ecu and convert it to 5 spd with this method correct?
I have been asking this question here local, but know seemed to know the answer.... </TD></TR></TABLE>
The method above is for 5g ECU. P5M
Old 06-12-2005, 07:29 AM
lunarcry's Avatar
Default Re: The official auto to manual ECU conversion thread (xbn83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">
The method above is for 5g ECU. P5M</TD></TR></TABLE>
sorry, I forgot to mention that.
Old 06-12-2005, 06:49 PM
K-Spec's Avatar
How do you de-solder the chip?
Old 06-12-2005, 09:24 PM
SoOHiGH's Avatar
Default Re: The official auto to manual ECU conversion thread (khalal538)
This should be FAQ and by any chance do you know how to do this on a 4th gen p13 ecu?
Old 06-12-2005, 10:37 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">How do you de-solder the chip?</TD></TR></TABLE>
I would do it with a fine tip on the soldering iron, some solder wick, and a pair of tweezers to grab the chip.
Old 06-12-2005, 11:13 PM
K-Spec's Avatar
Default Re: The official auto to manual ECU conversion thread (sharkcohen)
i thought when you solder something it connects the chip to the board...how do you undo? Do you just heat up the part connected and pull the chip out when it comes loose?
Old 06-12-2005, 11:15 PM
SoOHiGH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">i thought when you solder something it connects the chip to the board...how do you undo? Do you just heat up the part connected and pull the chip out when it comes loose?</TD></TR></TABLE>
its just melted in. you can undo it, but just be careful to not undo anything else. if you dotn knwo how to do it then you should take it to someone that does.
Old 06-13-2005, 04:51 PM
lunarcry's Avatar
yes when you solder, it connect whatever component to the circuit board in this case a resistor. you cannot just heat it up and hope it melt, you got to use a very fine de-soldering tool that will suck the solder that is been melted very fast and careful out of the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">
I would do it with a pair of tweezers to grab the chip.</TD></TR></TABLE>
I wouldn't recommend using tweezers in this case because you take the risk of grabbing it to hard to the point that the resistor will crack or snap in 2, remember this is a surface mount board what's holding the resistor on the board is the solder and in some cases some special non-conductive glue under the component. what I use a de-solder tool that you can get at radio shack and a small precision screwdriver to pry the resistor from the sides slowly also using magnifying glasses.
Old 06-13-2005, 04:55 PM
lunarcry's Avatar
Default Re: The official auto to manual ECU conversion thread (SoOHiGH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoOHiGH &raquo;</TD></TR><TR><TD CLASS="quote">This should be FAQ and by any chance do you know how to do this on a 4th gen p13 ecu?</TD></TR></TABLE>
I got no idea on how to do it on a p13, you should ask Jim Truett.
Old 06-13-2005, 06:46 PM
K-Spec's Avatar
Got it IN!
Old 06-14-2005, 01:43 PM
lunarcry's Avatar
good job man, does it work?
Old 06-14-2005, 02:13 PM
K-Spec's Avatar
ehhee...still doing the swap dunno until i put the tranny in...(installing clutch right now)...ill update you.
Old 06-14-2005, 06:24 PM
Lude S's Avatar
Too bad this thread didnt go up b4 i got my harness and obd1 ecu! My swap will be done tomorrow!
Old 06-14-2005, 06:45 PM
K-Spec's Avatar
Default Re: The official auto to manual ECU conversion thread (Lude S)
hey, something a little off topic...where did you run your clutch line through? I'm looking all over and that metal line is a b*tch...i was thinking of running a rubber hose instead.
Old 06-14-2005, 08:02 PM
Lude S's Avatar
A performance shop is ding the swap for me.........so i am not sure how they are running it. They started today and will be done tomorrow!
Old 06-14-2005, 08:17 PM
preludeguy_92's Avatar
the line doesnt have to be in perfectly just so long as you get the dampener in the right place in the end.
Old 09-14-2005, 11:32 PM
tdo
tdo's Avatar
Default Re: The official auto to manual ECU conversion thread (preludeguy_92)
If you guy want to do this to a 4th Gen P13 then all you have to do is remove <U>r11</U>.
btw i found this info on the pgmfi forum and im not responsible for anything that goes wrong while you do it to your car. have fun.
btw i just did it on a automatic p28 as well and its working great. (had to remove rp17 and rp18 then jump rp18)
Old 01-04-2007, 09:41 AM
Black-Engine's Avatar
Default Re: The official auto to manual ECU conversion thread (tdo)
Image is not working anymore...
I've got a P13 for my H22 4Gen...so want to do the conversion to. Can't find R11 on the ECU. Only RP11, but that's not the one, right?
So only removing R11? Not like the 5 gen =&gt; Placing the resistor elsewere?
Anyone got a pic also?
Thx
Old 01-04-2007, 10:25 AM
prelude1897's Avatar
Default Re: The official auto to manual ECU conversion thread (Black-Engine)
good stuff
Old 01-04-2007, 11:33 AM
E-Money's Avatar
Old 01-04-2007, 12:20 PM
hamadiscool's Avatar
Default Re: The official auto to manual ECU conversion thread (E-Money)
does anyone know anything about fitting obd1 ecu in a 5th gen auto?
Old 01-07-2007, 01:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Engine &raquo;</TD></TR><TR><TD CLASS="quote">Image is not working anymore...
Thx </TD></TR></TABLE>
Anyone please? Want to take a start with it...
Quick Reply: The official auto to manual ECU conversion thread
