CRV lift kit or bigger tires? off roadin
Old 05-30-2012, 01:51 PM
  #251
4cylfiend's Avatar
Default Re: CRV lift kit or bigger tires? off roadin
Originally Posted by Deatschwerks
My favorite color for the CRV!
Mine too!
Old 05-31-2012, 08:02 PM
  #252
inertiadrft's Avatar
I wonder if it will be ok if I run
15x7 0-offset with 215/75/15's on a 2nd gen Crv without a lift?
I'm so ready to pull the trigger on this, but I just can't help but be a little worried about fitment without lifting..
Old 06-02-2012, 11:17 AM
  #253
4cylfiend's Avatar
I think you will be fine since the 2nd gen has bigger wheel wells. If it does rub it will probably be in the front at full lock. You could always make a set of suspension spacers to raise the crv slightly. If you were local I would let you try my wheels on your rig.
Old 06-04-2012, 01:47 AM
  #254
Really? I had no idea the wheel wells are bigger on the 2nd gen, and that bit of info helps!
I'm gonna purchase a set of rims asap..
They are -6 offset, 3.3 hub bore, think thats good?
Thanks
Old 06-04-2012, 08:12 AM
  #255
ohm13's Avatar
Love the blue! Lift looks good.
Lifted the CRV last night! Thanks GAB20Z!!
Before:
After:
Old 06-06-2012, 08:48 AM
  #256
2000crv sport's Avatar
these are rims i am buying this friday 235/55/17 Pirelli Scorpion STR tires
has anyone run this tire on thier crv or other vehicle before ?
Old 06-06-2012, 03:09 PM
  #257
4cylfiend's Avatar
Thanks
Ya that should be fine depending on what size you go with.
Thanks man!
Old 06-07-2012, 04:47 PM
  #258
crv4me's Avatar
Hey All,
Just wanted to let you know that I ordered OME springs from Rocky Road on 5/22 and they arrived today 6/7. Not bad! Hopefully I'll be able to do the lift myself on the weekend. Wish me luck!
Old 06-08-2012, 07:02 AM
  #259
4cylfiend's Avatar
Originally Posted by crv4me
Hey All,
Not bad at all! Good luck with the install
The rear lower control arm bolts were a pain in the ***. One broke because it was siezed in the strut bushing so I ended up having to cut the nut off the lower control arm and buy a new bolt along with a new strut. Make sure you have a spring compressor handy too!
Old 06-08-2012, 09:21 PM
  #260
nix686's Avatar
Originally Posted by Disturbeds10
Damn that looks nice. I finally found a 5 speed. Its a 98 with 126k on it. Going tomorrow to see if I can get it with my trade in.. How much cutting did you do to the rear? Any kinda uptravel at all? Them Thornbirds make it look killer
Ya there is enough to do some like rocks and stuff mostly i just drive through ponds and atv trails. the front i ripped of the fender flares " flexing" on some rocks so i just bent the piece of metal that the fender flares are mounted to up. the rear same thing its trimmed to the door.
Old 06-08-2012, 09:33 PM
  #261
nix686's Avatar
Im pretty sure im running the biggest tires on here. new 31" duratracs went on last week. i was a bit skeptical because the are an AT not a MT like me thornbirds but, after driving them through a muddy pond about 22" deep I love these tires and would recommend them to anyone. also siping is ridiculous on these so should be great in the snow. I will need an additional inch or two of lift up front to not rub at full steer.
Old 06-08-2012, 09:43 PM
  #262
nix686's Avatar
I believe posted i was considering going 33s and a turbo, sorry to disappoint but i went with the 31s because i recently bought a 1985 chevy k10. all my time and money will be invested in completely rebuilding the truck. Built 5.7L 350 vortec, 8" procomp lift, 37" military Baja T/As, custom bumpers,.......
Old 06-09-2012, 07:07 AM
  #263
so i put the 235/55/17 's on yesterday will get a picture of it soon i dont think anybody has put a bigger tire then this on a stock crv withut rubbing but im not dissapointed with the tires they are nice and quiet at high speeds unlike my old tires and they look pretty nice i think
Old 06-11-2012, 11:37 AM
  #264
crv4me's Avatar
Thanks for the heads up. Just did the install this past weekend. Struts came out a lot easier than expected. My car hasn't seen too many miles from the PO so the bolts were good to go. Sprayed some PB blaster for good measure.
The rear install went smoothly. I believe one of the "nuts" are welded onto the arm if I remember correctly so you just need to remove it from the bolt side. Hopefully this wasn't the nut you had a cut off. Dropping the rear control arm makes the job much easier. Was able to use a spring compressor to replace the spring. The front struts on the other hand were a pain. Spring compressor wouldn't fit and the spring rate must be higher than the rears because the compressors weren't even doing its job. Ended up taking the struts to a shop.
As for the ride, it really did improve like everyone says. It seems to handle better and feels a bit more balanced than before. Previously it would lean towards understeering but now I feel like maybe I could even oversteer if I tried hard enough. Its a bit harsher on small bumps (ie speed bumps) but much smoother and progressive on dips. Maybe progressive isn't the right word but I can definitely feel increased travel and it feels smooth through travel. My tires used to rub on dips but now it's quiet.
My car has 215/75/15 BFG ATs. Here's an obligatory pic. Going to replace the stock rims with soft 8s in the future.
Old 06-11-2012, 11:51 AM
  #265
4cylfiend's Avatar
Looks good!
annnnnnd ya that was the one I had to cut off. Lol.
Old 06-12-2012, 03:25 AM
  #266
022vm's Avatar
akebonousdm.com SENDAI.JAPAN
Old 06-12-2012, 04:05 AM
  #267
4cylfiend's Avatar
^Nice!!!
Old 06-12-2012, 01:19 PM
  #268
^ yup nice!
I live the Spare wheel cover!
But what's with the 4 lug wheels on that Crv?
Old 06-12-2012, 09:42 PM
  #269
NZ-DB8R's Avatar
Its a 96-97 JDM CR-V, they were all 4x114.3, only 1998 and newer were 5stud
Old 06-12-2012, 10:21 PM
  #270
Got it..
Old 06-14-2012, 04:26 AM
  #271
is that 97 jdm even 4wd ?
Old 06-14-2012, 08:09 PM
  #272
well here is the rims tell me what you think !
Old 06-14-2012, 08:13 PM
  #273
forgot this one
oh and just too let you know im running 235/55/17 pirelli scorpion m+s tires, dont know the offset of the rim but no rubbing at all drives great
Old 06-26-2012, 09:31 AM
  #274
single cam fan's Avatar
^^^Did u lift it or just threw on the wheels?
Old 06-27-2012, 11:55 AM
  #275
i just put them on.... i hit a really bad bump once in a corner and it rubed but i also had a couple of boxes of plastic in the back weighing like 300lbs total :p
Quick Reply: CRV lift kit or bigger tires? off roadin
