[FAQ] D Series Torque Specs for everyone
Old 05-22-2009, 03:02 PM
  #26
Reject Papi
jhammond_82's Avatar
Default Re: [FAQ] D Series Torque Specs for everyone
man, this thread is 4 years old with new posts. lol.
Old 05-22-2009, 03:52 PM
  #27
89s1's Avatar
It's FRIDAY!
Have some e-beers for a great post back from the dead!
Old 08-16-2009, 10:07 AM
  #28
WNDOPDLR's Avatar
thank you so much for this. you just saved up a lot of aggrevation
Old 08-19-2010, 04:10 PM
  #29
JDMcivic801's Avatar
thanks. this helps a lot
Old 08-15-2011, 06:29 PM
  #30
SeanK325's Avatar
had to bump this. found all the info quicker than the dealer would have.
Old 11-24-2011, 05:17 AM
  #31
domster60's Avatar
will be cleaning or repalcing EGR valve..Anybody with the torque specs or do I nned it? thanks...
Old 11-25-2011, 03:26 AM
  #32
eddy jaydm ef9's Avatar
Thanks
Old 07-30-2012, 12:15 PM
  #33
Kannan08's Avatar
Hey HT, any idea what the torque specs are for the shifter bushings for a d16z6?
Old 07-06-2013, 04:44 AM
  #34
Xlthim's Avatar
Thanks for the info. It will be helpful in the shop this morning.
Old 09-22-2014, 05:18 PM
  #35
Kenny Sears's Avatar
Looking for k series torque specs. How do I search this site?
Old 01-06-2016, 08:35 AM
  #36
hamilton9339's Avatar
Hate to be a plunger an bring up old **** but the crank pulley spec is off 15ftlbs for a d15b7 anyways MANUFACTURE Spec is 134ftlbs and that's straight out of the factory service manual
CORRECT SPEC
Old 07-14-2016, 11:11 AM
  #37
Clarkscivic802's Avatar
Originally Posted by SOHCEK-Turbo
This is for everyone, I made this torque spec thread since I and many others here always ask about torque specs. Plus I myself, find myself looking trough all my Haynes and Chilton books for torque specs while I know I can make a list like this one to make it easier. I hope this can be some help and it can be made a sticky on these boards.
These torque specs are straight from the Chilton and Haynes manuals. I might also add some ARP torque specs as well. I still need to add more as you can see Ive been a little busy so as soon as I can I will add more. I would also be cool if others can add to it as well.
ALL TOQUE SPECS ARE IN FT-LB.
A/T Tranny Drain plug......................... 29
M/T Tranny Drain and fill plug..............30-40
Wheel Lug Nuts....................................80
Fuel Filter
Banjo Bolt............................................16
Service Bolt.........................................9
Clamp Bolt...........................................9
Valve cover Bolts...................................7
Spark Plugs..........................................13
Cam Gear Bolt.......................................27
Cam cover crown nuts.............................7
Crank(vibration) damper bolt...................119
Cylinder Head Studs....................1st step..22...2nd..49
Flywheel Bolts M/T................................76
Drive Plate bolts for A/T........................54
Header Bolts to Cylinder Head................22
Header to downpipe bolts.......................33
Intake Manifold Bolts..............................16
Oil Pan bolts...........................................9
Oil pick up tube bolts..............................17
Oil Pump to engine block bolts/nuts...........9
Oil Pump Screen bolts..............................8
Oil pump cover Screws.............................5
Oil filter Housing Bolts..............................9
Rocker arm shaft pedestal bolts................16
Rocker arm shaft end caps bolts................9
Timing belt adjstment bolt.........................31
Rod Bolts............................................. ....23
Main Bearings cap bolts
Separate caps and bridge..........................48
One piece cap assembly............................33
Connecting Rod Caps..........24
Water pump pulley bolts.............................9
Thersmostat housing bolts..........................9
Water pump attaching bolts.........................9
Fuel injection service bolts
88-90................................................ ......9
91up.............................................. ..........11
Throttle Body nuts.....................................16
Fuel Rail nut..............................................9
Manual Transmission
Countershaft locknuts................................65
End cover bolts.........................................9
Selector arm holder bolts...........................9
Tranny case to Flywhee housing..................20
Tranny to engine bolts
4 speed............................................. ........33
5 speed............................................. ........50
Clutch pressure plate bolts...........................19
Release fork bolts........................................22
Driveaxle/hub nuts.......................................134
Brake hose to caliper banjo bolts (front/Rear)...25
Master Cylinder Mounting nuts.......................11
Brake Booster mounting nuts.........................9
Modified by SOHCEK-Turbo at 2:37 AM 10/21/2006
Last edited by Clarkscivic802; 07-14-2016 at 11:14 AM. Reason: Torque specs for connecting rod bearing caps was wrong
Old 04-30-2017, 11:01 AM
  #38
Robert Kinnaird's Avatar
Thanks man this is going to help me a lot I'm rebuilding my 89 crx this spring/Summer..
Old 01-05-2020, 01:59 PM
  #39
Joe Fisher's Avatar
Can someone please tell me if these torque specs work for a 02 lx, D17.
if not, where in the world can I find the info. I have searched a a few days and no luck.
thank you, joe
Old 01-06-2020, 09:44 AM
  #40
Tyson's Avatar
thank you, joe
This forum is for 1988 1991 civics. You have a completely different car.
I googled 2002 Civic shop manual and found a lot of online resources. The torque specs along with everything else are available if you search. I won't post links.
Dkahn18
02-15-2009 08:35 PM
PrecisionH23a
03-01-2006 04:30 PM
SI_Ro
05-17-2004 09:32 PM
Quick Reply: [FAQ] D Series Torque Specs for everyone
