Let's talk about reshaping the combustion chamber to increase/ decreas compression - related to head
Old 02-04-2005, 06:17 AM
Black R's Avatar
Default Let's talk about reshaping the combustion chamber to increase/ decrease compression - head work
I know a stock b16 head vs a stock b18c head has a different volume and that by simply changing heads you can increase compression...
I'm really interested in how much you can open up the combustion chamber of a head to increase the volume, but at the same time how much compression do you lose?
And vice versa, a properly rewelded and reshaped (and of course ported + polished) head will be able to effectively raise compression as well... correct?
Since we are dealing with finite amounts of mass - what is the point of diminshing returns... I'm assuming you'll hit a coolant passage if you overport.
Also, how much can you raise or lower the static compression ratio by reshaping the head?
How much flow can you gain or lose by reshaping the head?
Let's talk about different head packages/ stages.
Let's not limit ourselves to stock bore - but discuss overbore (84-86mm) head's as well.....
Modified by Black R at 10:36 AM 2/4/2005
Modified by Black R at 10:38 AM 2/4/2005
Old 02-04-2005, 06:33 AM
b19coupe's Avatar
Default Re: Let's talk about reshaping the combustion chamber to increase/ decreas compression - related to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
This will also affect displacement, correct?
Combustion chamber volume does not affect displacement. Displacement is a function of bore and stroke.
PirateMcFred's Avatar
The ONLY things that change the displacement are the bore and stroke. You cannot do anything to the head to change an engine's displacement.
Adding or removing material, or changeing the volume of the head will affect compression.
Pirate
Old 02-04-2005, 06:37 AM
Black R's Avatar
Fixed post.
Thanks guys!
On with the discussion.....
NoSwapNoCare
03-23-2005 09:01 AM
Y2A
03-04-2005 09:03 AM
digital sol
02-01-2005 07:58 AM
flatty
01-25-2005 10:16 PM
gavhowe
08-02-2002 07:03 AM
Quick Reply: Let's talk about reshaping the combustion chamber to increase/ decreas compression - related to head
