ring gear holder
Old 01-08-2005, 05:18 PM
92hondalude's Avatar
Default ring gear holder
where do i get one?
Old 01-08-2005, 06:06 PM
satan_srv's Avatar
Default Re: ring gear holder (92hondalude)
...like what...a differential?
Old 01-08-2005, 07:12 PM
RTFM
v4lu3s's Avatar
hond part # 07LAB-PV00100
try that with a hond dealer.
if not try snapon or matco.
Old 01-08-2005, 08:20 PM
PirateMcFred's Avatar
When I put my ring gear on my Quaife I just took an old cut timing belt and nailed it to the leg of my shop table (4x4). Then I wrapped it around the gear about 1.5 -2 times so that when torquing the bolts the belt got tighter. It is ghetto but worked well.
Pirate
Old 01-11-2005, 10:14 AM
Default Re: ring gear holder (PirateMcFred)
no one at honda know what what part number is
by the way its for a flywheel
Old 01-11-2005, 11:05 AM
RTFM
v4lu3s's Avatar
thats the part # listed in the honda manual. so to your worthless honda dealer.
http://www.slhondaparts.com/se...se%21
07LAB-PV00100 RING GEAR HOLDER $89.64
Old 01-11-2005, 11:47 AM
Default Re: (v4lu3s)
89.64!!!!!!!!!!!!!!!!!!!!!! to hold a flywheel from moving!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-11-2005, 12:29 PM
Hawkze_2.3's Avatar
Default Re: (92hondalude)
Get a big fat guy to hold the flywheel still with a prybar. Hasn't failed me yet...
Old 01-11-2005, 05:32 PM
Prolink's Avatar
What are you doing that you need a ring gear holder? Is the crank pulley off? If not, use the crank bolt to prevent the flywheel from turning.
Old 01-11-2005, 05:53 PM
RTFM
v4lu3s's Avatar
i usually use a long angle iron with 2 holes drilled in it, so i bolt the angle iron to the flywheel with a pair of pressure plate bolts. that way i i have great levereage for breaking the flywheel bolts loose.
crxjarred
Transmission & Drivetrain
07-12-2014 01:21 AM
police vehicle tech
21
11-15-2009 08:12 AM
KayOs
10-21-2001 06:57 AM
Quick Reply: ring gear holder
