98-01 accord 4 cylinder head bolts torque specs?
Old 12-04-2004, 11:43 PM
BoostedSi's Avatar
Default 98-01 accord 4 cylinder head bolts torque specs?
Does anyone know the torque specs for the '98-01 accord cylinder head bolts (4 cylinder)? I searched but could only find specs for the '91 accord. thanks in advance.
BoostedSi is offline
Old 12-05-2004, 09:39 AM
BoostedSi's Avatar
Default Re: 98-01 accord 4 cylinder head bolts torque specs? (BoostedSi)
bump
Old 12-05-2004, 11:37 AM
BoostedSi's Avatar
anyone???
Old 12-05-2004, 04:57 PM
Beach Accord's Avatar
i will be back in tampa late tomorrow (monday).
i will give you the specs out of the helm manual if nobody has helped you by then...if you can just be patient and quit with the bumps.
Beach Accord is offline
Old 12-07-2004, 01:07 PM
Modified by Beach Accord at 7:03 PM 12/7/2004
Old 12-07-2004, 02:37 PM
matt_in_sd's Avatar
The purpose of measuring the diameter of each bolt is to make sure it hasn't stretched. If the diameter is not consistent it means the bolt has stretched and you need to replace it. You tighten the bolts in 3 (?) stages. The first stage you use the torque wrench. The second and third you turn the bolt a specified number of degrees. I will look up the details tonight.
matt_in_sd is offline
Old 12-07-2004, 02:43 PM
Default Re: 98-01 accord 4 cylinder head bolts torque specs? (matt_in_sd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_in_sd &raquo;</TD></TR><TR><TD CLASS="quote">The purpose of measuring the diameter of each bolt is to make sure it hasn't stretched. If the diameter is not consistent it means the bolt has stretched and you need to replace it. You tighten the bolts in 3 (?) stages. The first stage you use the torque wrench. The second and third you turn the bolt a specified number of degrees. I will look up the details tonight.</TD></TR></TABLE>
this i know..... i just didn't feel like typing it all in as the person who asked only really wanted the torque specs....and its two stages btw......
Old 12-07-2004, 02:53 PM
matt_in_sd's Avatar
Default Re: 98-01 accord 4 cylinder head bolts torque specs? (Beach Accord)
You only gave half the information. If this guy torques his head to 22 lb's and thinks he is done, he is going to be a little upset when he blows another gasket.
Old 12-07-2004, 02:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_in_sd &raquo;</TD></TR><TR><TD CLASS="quote">You only gave half the information. If this guy torques his head to 22 lb's and thinks he is done, he is going to be a little upset when he blows another gasket. </TD></TR></TABLE>
well he seemed honda knowledgeable and only wanted a number for a torque spec so i assumed he already knew what to do from there.....only reason i typed all that ish out was for verification, guy.....
Old 12-08-2004, 11:28 AM
matt_in_sd's Avatar
All this is per Haynes manual.
Step1 22lbs
step2 Tighten an additional 90 degrees
step3 Tighten an additional 90 degrees
If you are using new bolts:
step4 Tighten an additional 90 degrees
Old 12-08-2004, 11:39 AM
BoostedSi's Avatar
thanks
Old 04-13-2024, 11:29 PM
SirGuote's Avatar
This is for 1998-2002 Honda Accord.
Yes, I know this is an old forum but since I was looking for this same information not too long ago and found it I figured I'd reply to make it easier for others. MAKE SURE TO LOOK AT THE RIGHT SIDE OF INSTRUCTIONS TOO !! After torquing bolts you must turn to first mark (90º) then second (another 90º) and if new head bolts then finish to last mark ( one more 90º) making it a total of 180º or 270º if new bolts. Just want to make it dummy proof for those who are new to mechanics. Keep your dreams alive and build your car up !!
Last edited by SirGuote; 04-13-2024 at 11:53 PM. Reason: A better pic and better info..
SirGuote is offline
keithmay
02-01-2018 07:57 AM
LDTFbsst
03-16-2010 06:13 AM
Big M Built
05-22-2008 06:33 AM
BoostedSi
12-05-2004 04:41 PM
IanCT
07-05-2004 04:07 AM
Quick Reply: 98-01 accord 4 cylinder head bolts torque specs?
