> Honda CRX / EF Civic (1988-1991)
Old 11-14-2004, 10:39 PM   #1
friedEGs
friedEGs's Avatar
Send a message via AIM to friedEGs
Default Fuel inj. resistor box?? how to test... Injectors not spraying..
How can I test a resistor box out of my 90 ex? I have a problem getting fuel into the port. It seems like the injectors are not opening properly. Fuel is getting to the rail, and into the injector, just not spraying. Is this a sign that the resistor box has failed? Let me know any idea's, or suggestions. Thanks.
friedEGs is offline   Reply With Quote
Old 11-14-2004, 10:45 PM   #2
Redline130
Redline130's Avatar
Default Re: Fuel inj. resistor box?? how to test... Injectors not spraying.. (friedEGs)
Have you cleaned your injectors lately? Perhaps their stuck. If you can, try swapping out the resistor for a known good one.
89 CRX GSR Turbo~10.23 @ 145 mph
94 Civic D16Z6 Turbo~Guinea Pig
CARSS/SpeedFactory/Synchrotech Transmissions/Redline
Redline130 is offline   Reply With Quote
Old 11-14-2004, 10:47 PM   #3
doublethink
doublethink's Avatar
i lost injector pulse on my first ECU, same symptoms you describe. you need a multimeter to check for injector pulse.
try resistor box first, if that doesnt solve it, triple check all your grounds, especially at the ecu itself, and your 12 volt inputs.
if all is in order, you might end up buying a new ecu, as i had to do.
[1985 CRX Si -Sold] [1989 CRX DX -Junked] [1990 CRX DX (b16a) -Wrecked] [1990 CRX DX -Parted] [1991 CRX Si -Parted] [1988 CRX HF -Sold]
2004 s2000
Berlina MOB #040
doublethink is offline   Reply With Quote
Old 11-26-2004, 07:42 PM   #4
SiR Inspired ED7
SiR Inspired ED7's Avatar
iTrader Rating: (1)
yO, i have a B16a in my teg and is it necassary to have a resistor box?cause i bought it with out one reason i haven't bought one is i bpught the car like a month ago and barley getting to know it....
Using nitrous is like having sex with a hot chick with an STD, you wanna hit it, but your afraid of the consequences
I My Honda--ED Squad--Read the thread then Reply
SiR Inspired ED7 is offline   Reply With Quote
Old 11-27-2004, 06:54 AM   #5
dr_latino999
dr_latino999's Avatar
Send a message via AIM to dr_latino999
Default Re: Fuel inj. resistor box?? how to test... Injectors not spraying.. (92 DA B16a)
It depends, are you running an OBD-0 system or OBD-1? You can tell by the ECU code if you don't know what is supposed to be in around the engine bay.
Originally Posted by KIWIBird83
I love you quietone.
yes Hetero.
dr_latino999 is offline   Reply With Quote
Old 11-27-2004, 12:13 PM   #6
CRX_Control
CRX_Control's Avatar
Send a message via AIM to CRX_Control
Default Re: Fuel inj. resistor box?? how to test... Injectors not spraying.. (dr_latino999)
you can still run obd1 ecu with obd0 injectors and resistor box .
2001 Volvo s60 - Daily Driver
2000 Integra Gsr - ls vtec project car.
CRX_Control is offline   Reply With Quote
Old 11-27-2004, 02:04 PM   #7
krazie1
BANNED
Default Re: Fuel inj. resistor box?? how to test... Injectors not spraying.. (CRX_Control)
this is correct and MY current set up
krazie1 is offline   Reply With Quote
Old 11-27-2004, 03:11 PM   #8
alexdog69
alexdog69's Avatar
if it has been a long time since the injectors were last used... then maybe you have "bad gas" in them causing them to stick closed...
try tapping on the injectors to free the stuck pintles.. i.e. take a screw driver and put it on the body of the injector and whack it with a hammer...its just like a stuck float in a carb... just be careful that you dont damage the injectors or start whacking on the plastic portions..
if its a freshly swapped jdm motor, this is not terribly uncommon...
if this gets it to start up then run your first few tanks of gas with fuel injector cleaner in it...i.e. techron or lucas...
if you want to get all tough you could take them out and bang/shake them around a bit and spray some goo in them and try to clean them...
alexdog69 is offline   Reply With Quote
Old 11-27-2004, 04:39 PM   #9
ef8 h0!
Send a message via ICQ to ef8 h0! Send a message via AIM to ef8 h0!
Default Re: Fuel inj. resistor box?? how to test... Injectors not spraying.. (alexdog69)
i had the same problem, switched the resistor box didnt help. id have to say main relay, that also fires you injectors.
Good times had by all. Tune in next week for more. http://images.honda-tech.com/set1/smile/emsmile.gif
local night life: here
ef8 h0! is offline   Reply With Quote
arent, box, failed, fuel, honda, injector, injectors, pulse, resistor, s2000, short, spraying, test, testing, volt
