94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
Old 04-05-2010, 09:24 AM
  #326
byc_cb7's Avatar
Default Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
i did this swap and everything works except for the speedo anyone know what it could be? 95 hatch with a 94 integra harness.
byc_cb7 is offline
Old 05-02-2010, 08:51 PM
  #327
Kdub_81's Avatar
can anyone help me i wanna see if theres a thread to put a s2k cluster in a 99 ek hatch thanx
Kdub_81 is offline
Old 08-31-2010, 05:47 AM
  #328
Sporno's Avatar
everything on mine came out great, great write up, but i suggest doing one for an automatic to automatic cluster swap. Also mine seems to think 0 mph just sitting parked is 40 mph.. any ideas how to fix this?
Sporno is offline
Old 08-31-2010, 01:46 PM
  #329
r3devi7's Avatar
Skimmed most of the way through this thread, but cant find what I need. I have a 95 SiR cluster, I ave put in my 92 CX. Everything works save for the dimmer. Now from the pinout for the 92 stock cluster, do I only need to connect D4 from the green plug, to the correct pin on the cluster? It has an opening for a white 4-pin plug as I recall. Or do I have to connect D3, D4, & D5 in order for the dimmer to work? Or better yet can someone point me to where I can buy the EDM/JDM plug? Might be easier... Well thanks either way.
r3devi7 is offline
Old 10-13-2010, 04:18 PM
  #330
jdmcoupe86's Avatar
i also have a sir cluster in my ´95 2dr. everything works well, but the lighting is pretty poor. could it be, because in europe we have no dimmer? i have an ej2.
jdmcoupe86 is offline
Old 10-16-2010, 08:54 PM
  #331
mecheng101's Avatar
I searched for the answer in this thread and didn't find it, but I got a 94 Integra cluster to put in my 94 Civic but the cluster didn't come with the harness(es). Is there a way to buy them somewhere or do I need to go junkyard diving?
mecheng101 is offline
Old 10-21-2010, 01:23 PM
  #332
suprasalas's Avatar
hey man by any chance do u have the diagrams of a cluster for a 01 civic???
im trying to put it in a 94 civic.. but im having trouble wiring it.. can u help me...
suprasalas is offline
Old 12-01-2010, 11:44 AM
  #333
Savchuk_EK's Avatar
i already have an integra type r cluster in my car. i want to take it out and put a stock ek cluster in. will these diagrams help me at all?
Savchuk_EK is offline
Old 12-01-2010, 12:03 PM
  #334
BlueIntegraBoy's Avatar
Yes, you will need to work backwards.
BlueIntegraBoy is offline
Old 11-23-2011, 05:43 AM
  #335
scarhead1992's Avatar
with my ek cluster i was throwing a cel because i was running only one 02. now i did this put my teggy 95 ls in and no code. i would very much like to have my check engine light back. ideas???
scarhead1992 is offline
Old 11-23-2011, 05:06 PM
  #336
any chance anyone has got a howto or some pics of how they are holding their cluster in place. and i mean detailed. converted great not sitting good at all
Old 10-25-2012, 03:20 PM
  #337
Dainius's Avatar
hi i am new fore doing these things i just want to make sure if immobilizer not gonna give me problems if i do from 96-00 to 92-95 speedometer?
Dainius is offline
Old 10-25-2012, 05:05 PM
  #338
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Immobilizer is in the ECU so it has no affect on the cluster.
This is the best write up I have seen as far as mounting the cluster.
http://civic-eg.com/viewtopic.php?t=7301
speedjunkie_g35 is offline
Old 12-02-2012, 08:23 AM
  #339
FlackoNAEG's Avatar
I have a problem similar to 2 guys in this thread with the fuel gauge, when I had bought my 95 dx coupe shell(never knew if it was automatic or not), it came with a jdm 96 itr cluster, everything worked properly except for the fuel gauge. when it the fuel tank was empty, it would be just a tad under the half way mark on the gauge. I took that cluster out eventually to sell the car and put a 98+ gsr cluster with its own pigtails and it had the same issue...made sure I wired it correctly since it was different from the 96. So now I have a 93 Dx hatchback with a k20z3 swap that I know for a fact that it was automatic originally and installed my 96 jdm type r cluster into, and I still have the same problem with the fuel gauge. So my question is if has anybody figured out the issue? or if this is related to having a automatic chassis?
FlackoNAEG is offline
Old 12-02-2012, 08:22 PM
  #340
FlackoNAEG's Avatar
anybody?
Old 02-17-2013, 05:50 PM
  #341
jeremyhughes's Avatar
Love this thanks! going to pullapart tomorrow to pick up a new cluster for my crippled 95 dx hatch!
jeremyhughes is offline
Old 02-19-2013, 02:26 PM
  #342
MEn'MYEK's Avatar
I have question! My 98 ej8 doesnt have the orange 5 pin plug! Its a factory 5 speed car. So is that why?
MEn'MYEK is offline
Old 02-19-2013, 04:13 PM
  #343
olegles11's Avatar
wow thank you
olegles11 is offline
Old 02-24-2013, 12:20 AM
  #344
eg515's Avatar
Sorry to bring this thread back up. But i have a question i just bought a type r cluster for my 95 civic and all it came with was the 2 big plugs in the back of the cluster. Is that all i need or do i need the smaller one too ?? Thanks in advance
eg515 is offline
Old 04-05-2013, 10:59 PM
  #345
jdmkraziestyles's Avatar
Are the pin diagram for the integra the same as a rhd jdm integra wiring? Im looking for the VSS but its not orange and from what i found out its bluw/white. Can anybody confirm? Thanks!
jdmkraziestyles is offline
Old 09-04-2013, 02:49 PM
  #346
JaegerBomb27's Avatar
I am having problems with my fuel gauge working in the new dash assembly i just got wit the new wiring harness tht plugs into the cluster and everything else...well my old wiring harness has three blue plugs ins tht plugged into my cluster and the new whiring harness has only two blue plugs ins so my fuel gaue is off cuz im missing one of the plugs the cluster needs....what do i do and/or what kind of exact cluster do i need to fix this problem...plss help
JaegerBomb27 is offline
Old 12-05-2013, 04:37 PM
  #347
Tom_Chooch's Avatar
I used the pinout locations to re-rout my OBD1 94-95 Integra cluster pins to where the 98-01 dummy lights are located. This was a simple 3-pin swap to get the "faux 98-01" look in my 95 Integra, however the door ajar light is reversed when the ignition is off.
To explain further, when the ignition is off the door ajar light is on with doors closed and turns off when I open the door. Once I put in the key, it's all fine and normal... any ideas as to why the power to it is reversed when the key is off? For the time being I just pulled the door ajar light bulb but I'd like to get it back. Thanks!
Tom_Chooch is offline
Old 12-18-2013, 04:36 PM
  #348
carlosd68's Avatar
Trying to put 2000 Si cluster in my EG......the above diagram does not tell me what to wire D4 to.....does anyone know?
carlosd68 is offline
Old 01-02-2014, 04:50 AM
  #349
FMN716's Avatar
sorry to reply in this old thread need some help
I have an EDM sir spec ek4 and I bought the 98-01 JDM cluster
my problem is that my brake and fuel guage is now my indicators lol
FMN716 is offline
Old 02-18-2015, 11:05 PM
  #350
ANVIL's Avatar
Idk if mine is different or if RS is different or theres a mistake but i just did a 95 RS cluster in my 99 CX and the seatbelt light on my cluster is B2 not B1. The fuel gauge is B1 on mine.
ANVIL is offline
Quick Reply: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
