| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
My 2005 CRV has a ticking sound coming the left side of the vehicle. It sounds closer to the front then the rear. I checked the tires for rocks etc. but the noise is still there. My next thought was the drive shaft where it connects to the axle. Anyone with a thought on this? IG
Modified by iwgates at 4:35 PM 10/26/2004 Modified by iwgates at 4:36 PM 10/26/2004 Modified by iwgates at 4:37 PM 10/26/2004 Modified by iwgates at 4:38 PM 10/26/2004 |
#2 |
Is it only when you drive or anytime? I know that in most Hondas, that EGR vlave or whatever can make a loud clicking noise sometimes.
"Burn rubber, Not your Soul!" 2004 CBR600RR - SOLD 2004 Acura TL 2003 SV1000S |
#3 |
ticking, like rotating related, or something like engine constant such as valves?
2005 Subaru Impreza WRX 1995 DelSol VTEC 2002 Dodge Durango 5.9 R/T |
#4 |
Its only when the car is moving. it seems to increase in intensity, the faster you go. More like a rotating sound. It sounds closer to the lower left front than the engine area. Dont believe its the engine at this time, but Iam going to do some more investigation today. IG
#5 |
could be cv joint, but usually it wont go from working to clicking overnight unless u did some crazy stuff w/old shocks. Also check and make sure nothing stuck under your car, once I had a stick get stuck between my manifold and left wheel and was making a noise allot like you described.
#6 |
OK, thanks. I will keep hunting for it. At the present its seems to go off and on. I shall wait for it to get worse or just go away. it changes with the type of pavement which could be something like the stick stuck situation. I will come back when I have more Infro. IG
#7 |
It could also be a brake pad rattling inside the caliper.
Bird Man 03 Honda Pilot EX-L 04 Honda Element EX 02 Honda VTX 1800 C 76 Honda CB750 Chopper 00 Honda Harmony Lawnmower 04 Boston Whaler Montalk 17, Honda 90hp 4-stroke Outboard |
#8 |
since it is a 2005 go back to the Dealer and get it warranty...and let them know there re 2 bulletion for the car but not sure it applies to the 2005 but does for 2002-2004 ....shock mounts are not fully tighten from factory slightly loose...also tranny mount to close to trans and throught drivving and vibration trans and mount will rub or start hitting making noise...thats all i can remeber from the Honda Service....
topy
my vouches that I sold to: ff_terror, BlueIntegraBoy, jdm civic 2000, mikkellucci, Epoch, rexman, KLOW91, 94rs-turbo, h22-tech, nate_2k5, MIGS, PA Matt, clemsonhatch My For sale Thread MAD STUFF http://www.hondamarketplace.com/show....php?t=2563265 |
| Tags |
| 2002, 2003, acura, clicking, crv, drive, element, engine, front, honda, noise, sound, sv1000s, ticking, tl, vtx1800t |
