Car won't start after installing a new Radiator!
#26
Re: Car won't start after installing a new Radiator! (bluecivic107)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluecivic107 »</TD></TR><TR><TD CLASS="quote">You replaced the plugs and the cap...
I think this might be related to your problem...Double check your ignition wires connection to your dizzy. Check the sequence of your connection...</TD></TR></TABLE>
I didn't replace them right after I installed the new radiator. It wasn't starting after the new install so I started doing checks and troubleshooting everything that I could think of and then I replaced the plugs, cap, and rotor. All the wires are hooked up in the correct place so.....don't think that is the problem. Thanks for taking a stab at it though. Any help is appreciated.
#27
Re: Car won't start after installing a new Radiator! (Ace of Spades)
Have you checked all the ground wires bolted at the thermostat housing? Several ECU & ignition things are grounded there, so if one of those wires are busted that could explain it. You didn't unbolt them, but maybe you pulled on a wiring harness just enough to break one???
EGfosho
10
04-09-2008 08:50 PM
