b16 ed6 wiring help!!!
Old 08-05-2012, 06:18 PM
Taylorej1-93's Avatar
Default b16 ed6 wiring help!!!
ive been looking around here for a while and i can not find any good information on doing the engine wiring any help would be appreciated like do i need plugs off of the b16 harness or do i just use the d15 plugs oh its gonna be obd1 again please help i would post pictures but i dont feel like putting them on photobucket and then on here
Old 08-06-2012, 01:12 AM
villc713's Avatar
Default Re: b16 ed6 wiring help!!!
Is your car a Si or a dx?
Old 08-06-2012, 09:30 PM
it is a dx i know i have to do the v tec stuff but im thinkin i need some plugs off of the 2000 si harness. i know i need to do the injector plugs but im not sure what to re use or what
Old 08-06-2012, 10:34 PM
villc713's Avatar
First you have to convert dual point to multipoint fuel injection and then you can worry about dizzy wiring, injector wiring, and depending on if your staying obd0 or converting to obd1 ecu obd1 use a 4 wire o2 sensor, then you worry about vtec
Old 08-07-2012, 05:56 PM
i already have multi point im doin the ecu this weekend. i wanted to know about the plugs i need like alternator t stat and if there are other i just seem to have more plugs than i need
Old 08-07-2012, 07:26 PM
crx_si-r's Avatar
http://www.youtube.com/watch?v=puPiw...e_gdata_player
Done.
Old 08-07-2012, 07:27 PM
crx_si-r's Avatar
Start with this: what year is the motor? And what all came with your swap. This will determine what wiring mods will need to be done
Old 10-03-2012, 03:55 AM
mtflyboy25's Avatar
^ answer above and we can move on
Old 10-03-2012, 08:23 AM
its an obd 2 motor out of a 2000 si im also runnin a p28
Old 10-04-2012, 08:18 AM
i have the wiring harness also but i have already most everything i need off it
Old 10-06-2012, 09:11 PM
seriously nothing you could start by giving a hobo a rimjob
Old 10-06-2012, 09:30 PM
claymonthug's Avatar
to me it sounds like you might want to just buy something from rewire or buy a swap harness from someone on oh]p
Old 10-06-2012, 10:53 PM
crx_si-r's Avatar
txt me and i can get you exactly what you need
916-541-5266
or message me here or FB @ the link below
Old 11-14-2012, 12:10 PM
mccartermatt91's Avatar
i need some help i have a 91 ef hatch that im doing a b16a2 with a gsr head swap to and im trying to figure out what wiring harrness i need to start with and what all i need to do to it im running an aftermarket intake manifold i have 4 harrnesses here the gsr harrness a ls to ef conversion harrness a regular ls harrness and my stock ef harrness buddie had it all planned out and was going to help out but flaked any help would be awesome
B16ASilverhonda
12-06-2008 06:17 PM
SOHCEK-Turbo
11
03-06-2005 09:32 AM
turbo_civic_ek
10-28-2004 02:16 AM
Quick Reply: b16 ed6 wiring help!!!
