ITR brakes set up for 4x100
I have two remaned integra type r calipers only mounted no miles brand new centric premium rotors and brand new hawk hps pads. Rotors are 4x100 they are mini cooper rotors.
Im selling this set because i have a set of 15x7 rpf1's and they wont fit under the wheel. So i decided to tryin grind down the caliper bracket where it was touching the wheel and ended up going to deep on the driver side bracket and got down to the slider bolt (pictured) caliper is still perfect. Passenger bracket was never touched still in plastic.
-DS caliper and bracket will need new bracket
-PS caliper and bracket still in plastic and box
-Hawk hps pads only taken out to test fit
-D and P mini rotors one is still in plastic other was only taken out to test fit
taking offers want them gone.
Any qustions
Text me at 217-619-6748
Thanks, Dustin
Any qustions
Thanks, Dustin
Re: ITR brakes set up for 4x100
I pretty much have the same setup, under LS meshies and legend two piston calipers. I'm not sure what the offset on 15x7 rpf1's are but if you're on 23T brackets it should work without a problem.
Bump for a good price and parts, I'd buy if I didn't have mine already.
On the rpf1s the barrel is completely flat as it gets towards the face of the wheel it graudally gets small. My wheels are a 35mm offset.
Yeah they fit fine under 16's but 15's wont clear the caliper enough.
May even trade for 94-01 integra parts just let me know what you have.
