| Welcome to Honda-Tech! | ||
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today! |
#1 |
Garage is empty, add now
I've got a 1999 accord 4 cyl vtec with 208k. Checked the oil today and noticed a fairly strong gas odor from the dipstick which is not normal. The oil looked and felt ok at least on the dipstick. The engine seems to be running fine. About 2 weeks ago I noticed a mild rough idle after the engine was hot but it wasn't consistent. The car was just on a 500 mile trip with no problem although I think it burned about 1/2 quart of oil. I'm hoping it's just the PCV valve. Besides the head gasket what else should I be looking at?
#2 |
1996 Honda Accord |
Pull your spark plugs and see if any of them are wet with fuel.
Excessive blow by, incomplete combustion/fuel washing the cylinders and long periods between oil changes can be reasons for a gas smell in oil. |
#3 |
Pulled the plugs and they all look normal. I'm thinking the intake needs to be cleaned - since it's never been done with a 208k engine. Any other suggestions are appreciated.
#4 |
Did you replace the pcv valve ? You can normally tell if it's bad by shaking it and listening. It should have something rattling around inside.
__________________
91 Accord w/ H22A swap: Newest update on CARB cert...... Passed smog at the REF...Offically CARB certified !!!
