CLICK HERE all of you curious about suspension setups and their costs/reliability.
Old 09-20-2011, 09:37 AM
  #151
STOCK_SOHC_DX's Avatar
Default Re: CLICK HERE all of you curious about suspension setups and their costs/reliability
Originally Posted by Mister T
Libertariat, every time I see your car I cry a little, it's just so damn clean. I love Civics but I'm too damn big to fit in one comfortably LOL.
I didn't see the Megan EZ Street coilovers ($650-700, depending on where you get them) mentioned, might have missed it if they were. I know Megan gets a bad rap but I figured I'd throw my opinion in here. I've had mine on for about a month now but between my daily commute and a road trip down south I've already racked up quite a few miles in a very short time. They ride very comfortably compared to some spring and shock combo's I've had on other cars. I won't say they ride like stock, but to me they give comfort that's comparable to stock while still giving a tight and responsive feel. No bounce, no pogo-sticking over expansion joints and other imperfections in the road, no bone-jarring from bumps. That said, I wouldn't recommend them for track use. There are far and away better options for the performance-minded. The true test in my mind will be how they hold up in the next year but so far, so good.
Reason why they weren't mention is they are just not good shocks in the long run for the price. Progress CS-II same price range will blow those out of the water. They actually match their spring rate to shocks and I had my old ones(not CS-II) last nearly 11 years before I sold mine! The new owner told me that they were the best coilovers he has ever owned! haha
Old 09-20-2011, 10:02 AM
  #152
Ek Forever y0!
Libertariat's Avatar
I'll concede the rest of your post to STOCK SOHC DX
But, what is inherently different with shocks/springs and a full coilover? What makes them ride rougher?
Old 09-20-2011, 10:17 AM
  #153
TunerN00b's Avatar
Nothing of practical consideration.
Spring rates and shock valving.
Old 09-20-2011, 10:33 AM
  #154
Ek Forever y0!
My points exactly. The fact that they are not one piece doesn't make them worse/better.
It was a facetious question
Old 09-20-2011, 12:39 PM
  #155
JHall250's Avatar
You don't see bilsteins because I don't have any personal experience with them nor are they mentioned much on the forums I frequent.
Bilstein's are very well known in the Honda Community because they entered the market fairly late and because they don't have any adjustment *****. People in the Honda/Acura community love *****, its part of the whole "tuner" car thing.
The biggest difference between Koni and Bilstein is that Koni uses a twin tube design and Bilsteins use a monotube. What this translates to is Bilstein shocks use a significantly larger piston than the comparable Konis. And when it comes to dampers, the bigger the piston the more consistent the damping (assuming the quality level on the shocks is the same which in this case Koni and Bilstein are both of very high quality). In the Civic/Integra application Koni's pistons are between 36-38mm, Bilstein's are 46mm. Plus the Blistein's compensate for lack of a **** by allowing the user to tune their own suspension, parts support, tuning support, etc.
If anyone is planning on buying suspension I would highly recommend trying Bilstein's rather than Koni's.
An interesting read for those who haven't read it.
Autocross to Win
Old 09-20-2011, 12:49 PM
  #156
FlewByU352's Avatar
The only thing I could find on the Koni vs Bilstein was the Bilstein feel firmer over bumps or rebound very fast and that you can't go real low due to the bigger diameter unless you custom made extended top hats to fit the tube that big in there. Nobody ever said there was a vast difference or that it would be bad to chose one over the other. IMO both are very high quality dampeners, Koni is just more prevalent in the Honda community with prices hard to beat.
Old 09-20-2011, 07:31 PM
  #157
Mister T's Avatar
I wasn't making the argument that the Megan's, or any coilover for that matter, is better than a shock and spring combo via being one piece, nor was I stating that being a full coilover makes them less bouncy/more comfortable. My intention was merely to state my opinion of the product, based on my own experience. Believe me when I say I am well aware of the more popular and accepted products and I know full well the quality of the often recommended choices. Also believe that if the Megan's don't last or prove to be the pieces of **** people claim they are, then I'll be more than willing to share that. For now though, I am happy with my choice.
Old 09-20-2011, 08:46 PM
  #158
Master Detailer
98civdx's Avatar
People do know that 9 times out of 10 their "one peice" is noithing more then a shock with a damn threaded sleeve welded to it, right?
Old 09-20-2011, 10:36 PM
  #159
JHall250's Avatar
Ride height and top hats are not different between the two, Bilsteins work with Ground Control extended top hats the same as Konis and offer the same "damper trick" as Konis. There is no such thing as a "dampener" it's a "damper" and Konis are just more prevalent in the Honda community.
Old 09-26-2011, 05:28 AM
  #160
Hkustoms's Avatar
Libertariat
Would corner balancing the suspension when setting up the coilovers be beneficial? I'm particularly interested in shock travel for daily driving on crappy roads and then optimum suspension tuning for the track maybe once per month. Looking into a sway bar setup for a 95 del sol. While at it my 2000 Civic Si sway bar endlinks came apart. Thinking of just replacing the endlinks but I really don't know what would cause this...
Great thread.
Old 09-26-2011, 10:04 AM
  #161
TunerN00b's Avatar
Only for a race car looking for that last bit of performance.
For a street car, just set the spring perches at the same height left/right and call it "close enough" (after all, that's close enough for anything without threaded perches, including stock).
Also keep in mind that the car will generally look even less level after a corner balancing, which is generally not desired for a street car.
That said, I've had it done, and it only resulted in a very minor difference in on track performance.
Old 09-26-2011, 11:40 AM
  #162
I corner balanced my EK hatch and it made a huge difference on the street. Then again this was highway and mountain driving.
Old 09-27-2011, 08:55 AM
  #163
stocksucks85's Avatar
What about KYB shocks?
Old 09-27-2011, 10:20 AM
  #164
Ek Forever y0!
I didn't mention them because for the price there are better alternatives for not much more money. This question is going to get very old.
A lot of you don't realize that I don't offer a myriad of options FOR THE SOLE PURPOSE of making the decision easier.
I for one hold the belief that saving for the better/higher quality item is worth it in the long run. If I don't mention something it's because I feel that it is in YOUR best interest to wait and buy a tried and true setup that will last your car decades instead of months.
Old 09-28-2011, 02:12 PM
  #165
bnetkillzone's Avatar
Awesome write up!
Old 10-15-2011, 09:47 PM
  #166
JDMswagg25's Avatar
Wut about d2 suspension? I hear they ride pretty smooth and u could slam em pretty low too.. So y u feel they are in the bad companies list?
Old 10-15-2011, 09:50 PM
  #167
Master Detailer
98civdx's Avatar
Becuase they are shitty, low quality parts.
Is this even a serious question?
It's the OP's opinion, as well as many others that D2, SUCKS. I don't have them, but I know someone on here does. Post the pictures of the broken D2 coilovers.
Old 10-15-2011, 10:12 PM
  #168
Ek Forever y0!
D2's are fantastic. Clearly.
Old 10-16-2011, 12:58 AM
  #169
JDMswagg25's Avatar
^^ Oh dammmnnn.. How many miles it took u to have lookin like that and what type of setup
Old 10-16-2011, 09:34 AM
  #170
Master Detailer
98civdx's Avatar
What??
Old 10-16-2011, 10:45 AM
  #171
JDMswagg25's Avatar
Originally Posted by 98civdx
What??
Disregard my noobness lol... But ive seen and heard enough about D2s to convince me othrrwise
Old 10-16-2011, 11:03 AM
  #172
Master Detailer
98civdx's Avatar
being a noob has noithing to do with that. That is pure stupidity.
Is it really that difficult to use some proper freaking grammer?
Old 10-16-2011, 11:16 AM
  #173
The Grumpiest
grumblemarc's Avatar
It's Typespeak. It's the new texting language.
Old 10-16-2011, 11:56 AM
  #174
Master Detailer
98civdx's Avatar
I will ****ing back hand any of friends if they ever text me that kind of crap.
Thankfully most of my friends have some sort of an education.
Old 10-16-2011, 12:27 PM
  #175
Ek Forever y0!
Does it really matter?
PS. Have you ever read a book?
Quick Reply: CLICK HERE all of you curious about suspension setups and their costs/reliability.
