1995 honda civic tire sizes
looking all around
looking to see if 225/45/17 will fit in my eg hatch
found bigger tires saying they will fit but no pictures to back it up
if anyone has this tire size on an eg or ek plz post them
Re: 1995 honda civic tire sizes
the wheels i have now are drag dr 30 15" and tire size are 195/55/15
and lowered about two inches
but for the winter i raised it some and put some snow tires on the car il post pictures later today
winter wheels are 13" and 175/75\13
You want to try and preserve the stock tire diameter, to keep the speedometer and odometer accurate. Going larger can cause rubbing issues in addition to throwing the meters off.
195/50-15 and 205/40-16 are the best sizes for the car, keeping the diameter close to the stock 22.7 diameter.
A 205/40-17 is a bit larger, and could cause rubbing issues on a lowered car, since it is 23.5" in diameter, but that is the closest 17" size available.
225/45-17 is huge for your car, at close to 25" in diameter. You probably aren't going to find pictures of a 95 hatchback on this tire size.
The correct tire size for an Integra is larger than for your Civic, but that is still too large of a size to be correct on an Integra.
SNatCH 1.6
09-11-2006 11:13 PM
