Is it must that I use Honda ATF fluid?
Old 12-12-2010, 02:07 PM
averyvm's Avatar
Default Is it must that I use Honda ATF fluid?
Hey Guys,
I got a 93 Civic LX, and the tranny went out, so I got a new one. I just put the new tranny in last night. Before I start it up I wanted to ask a few questions.
1.) Should I put fluid in with it running or off.
2.) should I check the fluid level with it running or off.
3.) Is it a must that I use Honda ATF/ Can I just get some from Autozone that says its ok for hondas
Thanks Guys
-AVERY
Old 12-12-2010, 02:16 PM
SeanK325's Avatar
Default Re: Is it must that I use Honda ATF fluid.
1. while the car is off
2. while the car is off. when the fluid begins to overflow from the exit bolt, that's when you know you're full.
3. yes, you must use honda transmission fluid. autozone doesn't know ****. their system should say, "Dealer Fluid Only." Like that of O'Reilly.
Old 12-12-2010, 02:32 PM
averyvm's Avatar
Thanks Sean
Old 12-12-2010, 02:55 PM
SeanK325's Avatar
Yep. There's a write-up here on how to change the trans fluid that is really nice and clear.
Old 12-12-2010, 03:10 PM
shyboi4u's Avatar
From the title. Seems to me that it's an Auto tranny.
Old 12-12-2010, 04:34 PM
Linked's Avatar
auto transes dont have fill holes, they have the dipstick in which you pour atf in that way i think
Old 12-12-2010, 04:42 PM
Pothole987's Avatar
Honda engineered its fluid especially for these cars.
Old 12-12-2010, 06:36 PM
V.MoMO's Avatar
on #3
also dude can that be my sig, its so true and funny
they wanted me to use motor oil for my 5 sp TRANNY, its a tranny not a MOTOR!!
Old 12-12-2010, 06:52 PM
318 Curves, 11 miles
Vindicator9000's Avatar
Originally Posted by V.MoMO
on #3
The owner's manuals used to say that motor oil was acceptable for manual tranny fluid in some of the earlier Civics. Truth. It works in a pinch, although obviously not optimal.
As far as ATF: I've personally had bad experiences running non-Honda ATF in Honda automatics. My CRV seriously doesn't want to 2-3 and 3-4 shift with non-Honda fluid. My old Accord hesitated on shifting too with non-Honda fluid.
Since I found that out, I always use Honda fluid now.
Old 12-12-2010, 07:11 PM
V.MoMO's Avatar
Default Re: Is it must that I use Honda ATF fluid?
i know that the motor oil COULD be used but i never hurts to use honda products
Old 12-12-2010, 07:14 PM
Linked's Avatar
OP needs to tell us if he has a AT or MT
Old 12-12-2010, 07:18 PM
V.MoMO's Avatar
i believe if he is talking about ATF then its probably an automatic
Old 12-12-2010, 07:52 PM
SeanK325's Avatar
I didn't even see that it was an auto. I'm so used to manual trans. sorry.
you can use 10w-30 if I'm not mistaken in your trans if Honda fluid isn't available. but you should always run OEM stuff.
Old 12-12-2010, 08:06 PM
jayWknight's Avatar
NO, never ever use engine oil in a automatic transmission. 10-30w is only a sub for MTF and not for ATF.
Old 12-12-2010, 08:21 PM
V.MoMO's Avatar
dude sean can i use ur words for my sig, u must have missed it
Old 12-12-2010, 08:52 PM
SeanK325's Avatar
Learn something everyday.
Yeah its all good.
Old 12-12-2010, 09:50 PM
V.MoMO's Avatar
awesomeness = -----------v
Old 12-12-2010, 11:54 PM
SeanK325's Avatar
lol... i never thought i'd see the day.
man, auto trannys work on some kind of magic dust. i'll stick to my 5spd.
Old 12-13-2010, 04:03 AM
Resident Gearhead
BryanM.'s Avatar
Use Honda ATF if it's an auto
Use Honda MTF if it's a 5 speed
10w-30 or 10w-40 can be used as a short term substitute in 92-00 5 speeds.
singher01
07-25-2008 10:19 AM
djviet2000
12
06-14-2007 10:54 AM
lv6l
Acura TSX
10
04-06-2007 10:22 AM
square_1
07-22-2006 09:30 AM
onyx00
10-27-2001 07:56 AM
Quick Reply: Is it must that I use Honda ATF fluid?
