Rear tires scrubing from wide rims and tires.. HELP
Old 06-25-2014, 08:06 PM
acanby's Avatar
Default Rear tires scrubing from wide rims and tires.. HELP
I have a 93 lude vtec that ive been working on for 3 years now or so its given me a lot of issues but this one is my own fault for not quite knowing what I was getting myself into, I bought 17"x8" rims a few years ago and 245/40/r17, and because of the small lip on the rims they cause the whole thing to stick out further. I have stock KYB shocks on the front and rear that I put in about 2 years ago, and they work just fine, accept the rear absorbs so much that I scrub quite often. Is there a aftermarket company that sells rear shocks that are stiffer than OEM but around the same height, or maybe a tad lower? Just curious on what the hell I should do without getting rid of the tires and rims. PLEASE HELP !!!?!?!?! Any knowledge will help me !@!
Old 06-26-2014, 09:12 AM
Moderator
snobordboy's Avatar
Default Re: Rear tires scrubing from wide rims and tires.. HELP
Your height is a function of the springs, so you need a stiffer or taller spring, or an adjustable coilover.
The cheapest option would be to use spring helpers, just rubber that goes in between coils of the spring to keep it from compressing so much.
If you are just scrubbing the tires on the fender a bit though, have you rolled the fenders at all, that may be all you need.
Old 08-01-2014, 01:43 PM
acanby's Avatar
ah okay that makes sense I was thinking about rolling the fenders too that would help, and alright that sounds good ill try that out
o0oitsthaitea
01-08-2011 02:39 PM
mangberto
08-25-2010 07:47 PM
cree
Suspension & Brakes
03-14-2005 05:16 PM
austrian type-R
04-25-2003 08:46 PM
Quick Reply: Rear tires scrubing from wide rims and tires.. HELP
