Pilot 2005 needs expert support
Hello everybody
All my friends recommend this place like a land of experts to put my problem between your hands.
I have Honda MR-V 2005, once I bought this car from auction the check engine light is on and this last for two days.
I noticed that RPM of the motor cann't exceed for any reason more than 5000 rpm.
after changing engine oil the check engine goes off, however randomly check engine light goes on and off, but still the same issue the rpm cann't exceed 5000 rpm.
after 1 days from changing the engine oil, and while I was driving suddenly the car goes off and a little bit before I was sensing a low torque and less power from the engine.
I start the car again but here I cann't exceed 2300 rpm or less and check engine light still on.
Small noted when I m shifting to R I hear a shock voice but not in D drive.
I put my problem between your hand.
Thanks is advanced.
Thanks is advanced.
1 Post
Re: Pilot 2005 needs expert support
Well I will be glad to help you . I need to know what codes are you getting on the check engine light you can scan the pilot with a obd scanner at any advance auto parts and get the code in here I can glady help you
Hello My friend finally I receive a reply
codes are P2176- P2135- P2195
Thanks EK FLY
1 Post
DTC P2176: Throttle Actuator Control System Idle Position Not Learned
on this code it looks like someone disconnected your TB. wile the car is running / it look like your problem is on the Throttle body check for any damage or any cut wires . to fix this you will need to take your car to a honda dealer and have it relearn
DTC P2135: TP Sensor A/B Voltage Incorrect Correlation
remove your intake tube and check for any obstruction on the Throttle body - plate or see if it actually closes
DTC P2195: Rear A/F Sensor (Bank 1, Sensor 1) Signal Stuck Lean
DTC P2197: Front A/F Sensor (Bank 2, Sensor 1) Signal Stuck Lean
these 2 can be related to the 2 above
streetchemistry2000si
12-15-2008 09:42 AM
