March FS Thread
Moderator
March FS Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
4) NO WTB ADS!
Skunk2 pro series valve springs n titanium retainers. These were installed but never started or ran. 250 shipped obo for the springs 150 shipped obo for the retainers. Or 375 shipped obo for both. Thanks for looking. Mike best contact is text/call 7173855542
Re: March FS Thread
FS: Mil-spec Hondata CPR harness. Replace that bulky, electrical taped harness that they supply with the Hondata CPR kit. Also replaces the ugly blue colored K-series cop connectors.
All brand new connectors, pins, seals, etc. Raychem DR-25 heat shrink, Raychem adhesive shrink, Teflon coated Tefzel wiring, Deutsch quick disconnect connector and OBD1 distributor plug for a plug and play engine bay setup. Qty. 1 forsale in this configuration.
Price = $200 shipped in the states.
FS: GSR Cylinder head. Ported by Head Games. Fully built. Ferrera stainless valves, Supertech valve springs, Supertech Ti retainers. Built with bronze valve guides, OEM valve stem seals, new OEM LMAs, etc. Head was rewelded and ported in the water jacket near cylinder 1. Head was then resurfaced. Head has been used for six events. Normal wear on rockers and cam caps. Does not come with cams or valve cover or vtec solenoid/sensors, etc. Brad Penn oil run at all times. Any questions ask.
Price = $1000.00 shipped in the states
FS: 1.75 gal aluminum fuel cell. -12 feed, -8 return, -4 vent. Comes with billet filler cap with seal.
Price: $200 shipped in the states.
FS: USDM ITR 4.40 final drive ring gear and main shaft. Excellent condition. 66T and 15T. Selling for $150 shipped for both. $80 shipped each.
FS: LS 4.266 main shaft. 15T. Good condition. $25 shipped.
Re: March FS Thread
For Sale: FJO Injector Driver with obd1 wiring harness that is wired for the injector driver. Harness is for single plug distributor.
$200 FJO injector driver with prewired obd1 engine harness
Injectors in picture are not included. They have already been sold.
Re: March FS Thread
FOR SALE:
ID1000 1000cc injectors. Never used and new in packaging. Still have the connectors in them to adapt your harness to work. Setup to work with B Series engines. $425
Stealth 340 LPH pump, new in packaging. Opened for pictures. Never installed. $125
OBX Helical style LSD. Never installed, customer bought for a build and he chose to run a spool. New in packaging. $SOLD
Skunk2 ULTRA Street manifold. New in box, never installed. Has all of the fittings and plugs to go with it. Customer chose to go bigger. Brand new and fits ALL B series heads. $SOLD
Buyer will pay all PayPal fees and be responsible for shipping charges. Thanks!
Injectors ID1000
Stealth Fuel Pump
Injectors ID1000
Stealth Fuel Pump
Re: March FS Thread
I have a few things laying around. I have an 90-93 integra ETD traction bar. It is and has some surface rust on it, but doesn't affect anything. I had it tack welded in so it has weld spots on it. Also have a Lighter-Faster carbon fiber sun roof plug. I had it on my for less then a month and never left the garage. It is drilled but in great shape and great quality. Plus a bucket of random A.N. and pipe adapters and plugs. Lastly have 90-93 jdm integra fenders in decent shape.
Plug $150
traction bar $150
adapters $50
Plug $150
traction bar $150
adapters $50
706-346-6024 matt.stover@comcast.net
FS: Forward Facing Manifold. one off manifold. This is a friend's stuff that i threw on my car to take the pics so you can see how it all sits. $650 Shipped
**Option: I can have this thing ceramic coated FOR YOU for a non negotiable price.
$200 additional
706-346-6024
$200 additional
706-346-6024
Re: March FS Thread
Autometer tach/shift light $250
Avid solid mounts passenger is a auto to manual mount $300
Fluidyne half core radiator $150
Be cool electric fan $150
4" down pipe with Burns muffler $225( made for Full race top mount)
T1 race intercooler with 3" J-Fab intercooler piping $800..no bov included, however all clamps and couplers included.
XS Power 16 volt battery purchased new at the end of October have receipt used once $200, also have the same battery but 1.5yrs old that will only hold a charge for one pass. asking $75
Rywire OBD1 B-series harness with ID injector clips! $375
Integra shift linkages with skunk 2 short shifter and **** with prothane bushings $100
LS gear set missing diff and ring gear
GSR trans with diff and b16 ring gear has both cases
Misc shift forks and Shift changers. Both gear sets are in unknown condition. $400 for all trans pieces listed above.
B series swap mounts with prothane inserts and avid torque mounts. Comes with everything pictured. T bracket is from a 94-01 Integra along with all the mounts. $150 will not part out.
B series axles in working order $75
[URL=http://s669.photobucket.com/user/WillisSFWD/media/20131201_201925_zps050b8fa4.jpg.html][IMG]http://i669.photobucket.com/albums
Pro comp performance b16 aftermarket head. This a NEW casting never been bolted on or used. The head has been hand ported with a "Outlaw" port job. My plan was to compare this head to the exact same head i had sent off to 4 piston, but due to financial issues I'm forced to sell. $500.
Re: March FS Thread
Lovefab H22 Turbo Manifold has one broken bolt in turbo flange, bought it that way-$550 obo
Rc 1000 Inj Bnib-$300 obo
Prices are obo, paypal and shipping w/ insurance extra
Re: March FS Thread
Fully built Golden Eagle sleeved gsr motor, 84mm, NEW Cp pistons, NEW eagle rods, new bearings, new headgasket, arp studs, moroso oil pan.
GSR head Skunk 2 tuner 2 cams, skunk 2 pro series springs and retainers with supertech valves.
Asking $3200 firm! Txt 239-331-9835
Re: March FS Thread
Hi Guys I'm selling My B-Series Outlaw Water To air Setup it has been custom fabricated it is in excellent condition. This system is for water to air setup but intercooler can be replaced for Air to Air. I fabricated the setup a while back, but never ran it i decided to take it off and enter a different race class. These parts are in immaculate shape their is absolutely no problem with this. I only used it for mock ups after it was constructed car never even hit the Dyno on this set up. This setup is good for any Bracket car or Index car that wants to play and have fun, but if you want play with the big Dogs at Outlaw You can. I had these parts in my storage for too long now its time to sell it.
Includes:
1. (4) 3'' 16G charge pipes (Made to Fit a Fullrace top mount or similar Topmount)
2. 5 inch Water to Air Double core Intercooler 3'' outlets (Same DImension As most Air to Air so it can be replaced)
4. All T bolts Clamps and Cupplers Needed
5. Water To Air Ice Resevoir (Cold side Pipe Gets freezing cold also and it has a fuel cooler coil Built in that cools off the fuel right before it enters the FuelRail)
6. Water Pump for this setup
7. All Lines A/N-12 included
Asking Price $980 OBO. PayPal Ok.
Foward Facing Kooks Kustom Outlaw Manifold (material is SCH10 T4 Divided with 1/8NPT EGT bungs that can be plugged and chrome Ceramic coating. WG exit is divided and diameter for 60mm -with no flange or WGate)
Asking For $580 OBO
Please don't waste my time if you are not serious. I'm willing to ship at buyers expense I will send Requested Pics of any part to anyone who is serious in buying it My Email KVFAB.VP@GMAIL.COM, I rarely log on to HT check my inbox for quicker response you can always text me 201-494-1621 or call
Includes:
Asking For $580 OBO
Re: March FS Thread
Aem V1 obd2a 1060 box $550 shipped in the US.
Pm, call, text
612-7O3-2OO1
I'm the original owner of the box purchased it new in 2007
Pm, call, text
612-7O3-2OO1
Re: March FS Thread
Mfactory gear stack. Pro series gears except 2nd. Comes with two 4.05 final drives. And extra first gear. The spare parts are brand new. Synchrotech synchros and liberty cuff. The stack has ten hits on it, car went 9.4's with it. I bought this from dynamic, and I haven't used it. Decided to go with a dog box. $1500.00
Full b series turbo kit. All you will need is a blow off valve. Borg warner s366xl T4 1.1. Turbo comes with the coupler and -10 drain. Couple hundred street miles and a few dozen track passes on the turbo and manifold. Brand edelbrock victorx which I had powder coated. Top mount manifold 46mm vband wg flange. Precision 46mm wastegate and dump tube. I have the box and everything it came with. 4" up pipe ceramic coated. Blox 72mm billet aluminum throttle body. 3" polished intercooler piping with vanjen clamp on throttle body. Precision 800hp core with back door on inlet side. Comes with carbon fiber hood that's already cut out for the up pipe. $3500.00. I just had the intercooler, intercooler piping and up pipe fabbed up. Its brand new. Going with a forward facing setup, that's the reason for selling. Came off of a eg hatch chassis. $3500.00 obo
MSD vtec wire $35 shipped.
(2) -10 catch can lines. Theres enough slack to use these on the back of the block or intake manifold side of valve cover if your can is where the battery use to be. $45 shipped.
Re: March FS Thread
All prices are + shipping and paypal fees.
Rolling shell-$10k non neg price! Don't ask! This is a crackhead price! 25.5 cert chassis, Progress custom coil over setup, custom front, shaved bay, custom flat paint by Goolsby customs, fiberglass tailgate, CCC spoiler, carbon hood, weld ...rear skinny's, Exospeed 15x9 fronts with 26x9 toyo's, Kirky seat, stroud window net, custom staging brake, stroud parachute, sumped tank, Mfactory LCA, and I don't know what else I'm forgetting. I also have enough carbon wrap to do the hood, tailgate, and rear diffusers. I will do that before it leaves here.
Chase Bays b series mil spec harness-$1000
Used Golden eagle B series head studs-$90
Used oversized flat bottom valves. sold
UPR billet intercooler water tank lid-SOLD
New Honda engine bearings-$125
There are 26 bearings in there. Probably $250 worth.
15 used Crower valve spring retainers. 1 missing for some reason.-$75
New MSD distributor cap for b series-SOLD
MSD HVC 2 coils. all but the blue one sold -$100
AEM fuel rail for b series with sample valve and SX regulator-$150
PWR radiator w/Spal fan for 92-95 civic-$150
Turbo smart 40mm wastegate-sold
Hks bov-$50
Unknown intercooler-$50
OG B series Spec twin disc clutch-SOLD
Intercooler water tank-$50
F22 drag turbo manifold-$50
B18C1 CNC race head for sale. This head was used in the BRE Hot Rod car, but has been reworked with a new valve job from CNC. It's all done, just needs to be professionally assembled. I know I would prefer it this way so everything can be confirmed to be correct during assembly. Valves, springs, and retainers are Ferrea. Comes with keepers, shims, and seal. All cam caps and oil rails included too. SOLD
Xenocron b series cam degree kit. SOLD
JG Edelbrock intake for B18c1 sold
BDL 70mm throttle body-$200
Weldon 2025 fuel pump with fresh rebuild from Weldon. Filters included-SOLD
MSD 75314 4cyl ignition box w traction control-$600
Stock B18C1 longblock, new cam seals, rear main seal, oil pan gasket, valve cover gasket, oil pump, water pump, tensioner, and timing belt. Was gonna be my beater engine, do it's got everything you need new to mske it run for a long time. $1250 timing belt and cover not in pic. also, will have stock oil pan and pickup installed.
Hks bov-$50
Re: March FS Thread
91 CRX HF drag shell. NO RUST at all! Car was originally from Texas. Custom hand bent 10pt cage by Tom at Fabrications Unlimited. Cage is complete with door swing outs and a removable parachute bar with cable. Everything is tig welded and good for 8.50s. Up front there is a Vibrant 875hp intercooler with custom 3 inch piping, all covered by a urethane wings west bumper (intercooler is too big for stock bumper). 4 wheel disc brakes and camber kit up front with extended studs. Full interior is present even with full cage, the door bars were even designed to work around the original door panels. I have all headlights and dent free panels so this is a complete roller. Simply drop in your swap of choice and race. All electrical harnesses are included. Car comes with one B-series transmission as a free extra along with a sumped fuel tank. $2000 Cash NO TRADES. There is 3k worth of cage work alone! Located in Maryland 21111
