92 Accord EX - How to change front headlights?
Old 01-01-2005, 01:32 PM
lindy3080's Avatar
Default 92 Accord EX - How to change front headlights?
Does anyone out there know how to change out the front headlight BULB of a 92 Honda Accord EX? The owner's manual doesn't say, and after trying to fish around with my hands I'm afraid I will break plastic and be bummed.
Using a mirror, I can see behind the headlight assembly under the hood. There is a black circular ring around a white plastic piece. The ring has the words Open and Lock with opposite arrows next to either one. But the thing won't budge when I try to move it in either direction.
Anyone know what to do?
EDIT: I don't need to replace the whole headlight assembly. I only want to replace the bulb.....
Modified by lindy3080 at 3:19 PM 1/1/2005
Old 01-01-2005, 01:44 PM
kevinm1981's Avatar
Default Re: 92 Accord EX - How to change front headlights? (lindy3080)
you gotta remove the front bumper and bumper support
Old 01-01-2005, 02:21 PM
lindy3080's Avatar
Default Re: 92 Accord EX - How to change front headlights? (kevinm1981)
I just need to replace the bulb, not the assembly. I shouldn't have to remove the assembly to do that should I? On the rear of the assembly it appears as though I can unscrew a black plastic ring which will free the bulb to be removed from the rear. BUT, the ring will not rotate. Is there something else I need to do?
Old 01-01-2005, 02:28 PM
darwinizm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinm1981 &raquo;</TD></TR><TR><TD CLASS="quote">you gotta remove the front bumper and bumper support</TD></TR></TABLE>
wat he said
Old 01-01-2005, 02:44 PM
lindy3080's Avatar
Default Re: 92 Accord EX - How to change front headlights? (mysterious_2)
in order to replace a headlight bulb you have to remove the front bumper? surely not...???
Old 01-01-2005, 02:50 PM
kevinm1981's Avatar
it says Headlights, not headlight bulb, stupid girl
Old 01-01-2005, 04:40 PM
jdmcb3's Avatar
turn the black trim ring around the light bulb counter clockwise to unlock the bulb
Old 01-01-2005, 05:20 PM
Lostcb7's Avatar
Default Re: 92 Accord EX - How to change front headlights? (jdmcb3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcb3 &raquo;</TD></TR><TR><TD CLASS="quote">turn the black trim ring around the light bulb counter clockwise to unlock the bulb</TD></TR></TABLE>
You are correct. To get the trim ring to move you might need to use a flathead screw driver and a hammer to get the thing turning. Remember these things are probably on moved every few years, if that, so they are going to be a bit tight. On the bulb there are 3 flat tabs sticking out that will line up with the holes on the trim ring. Match them up and the bulb pops right out. Hope that helped.
Old 01-02-2005, 02:04 PM
lindy3080's Avatar
Default Re: 92 Accord EX - How to change front headlights? (Lostcb7)
Thanks, Lostcb7. I appreciate your kind and thoughtful reply. I was able to replace both bulbs using your tips. The plastic rim was on there very tight, and I used a flathead and hammer just like you suggested... without worrying that I was inadvertently going to break any plastic.
My husband and I just moved from Nashville to Atlanta, and I am not surprised that the nicest reply to my post came from there! It's a shame some people from Kent, Washington, are so desperate to feed their egos that they grovel with lame attempts to belittle others.
Thanks again for your helpful reply.
Old 01-02-2005, 03:09 PM
Lostcb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lindy3080 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, Lostcb7. I appreciate your kind and thoughtful reply. I was able to replace both bulbs using your tips. The plastic rim was on there very tight, and I used a flathead and hammer just like you suggested... without worrying that I was inadvertently going to break any plastic.
Thanks again for your helpful reply.</TD></TR></TABLE>
Your welcome, glad I could help I had to learn the hard way through trial and error and lots of cursing. As for the people with the negative responses, you really have to watch out for those e-thugs, they are real hard asses.
Edit: If you plan on addressing more general maintenence issues with your car, it would be very beneficial to pick up a Haynes manual at your local Auto Parts store.
Old 01-05-2005, 08:26 AM
New User
mrvinyl33's Avatar
Good call for the flathead screwdriver. I couldn't get mine to move either until one was used. There were serveral of us trying to do it, they all thought I wasn't strong enough to turn it until they realized none of them could. At that point I remembered that the screwdriver trick and voila!
Old 01-05-2005, 10:20 PM
Trumpster's Avatar
Default Re: 92 Accord EX - How to change front headlights? (mrvinyl33)
Haha, good times. I remember having trouble trying to figure out how to get mine out too. I actually tried twisting the bulb before I figured out that it was the black ring AROUND the light that I had to turn. I actually broke the plastic plug where the wires plug in completely off! I got that all figured out, now I just need to find some good bulbs that are bright and have good distance (that don't burn out between 20 and 90 days )
Old 01-24-2011, 04:02 PM
chiko321's Avatar
Hoping to get better leverage, I wedged a screwdriver in one of the slots on the back of the ring and broke it as soon as I struck the screwdriver. Obviously I can change the bulb now, but the ring is very loose. Where can I get a new ring? Must I buy the entire headlamp assembly? Surely not!?!?
Old 01-26-2011, 06:46 PM
uberEFtuner's Avatar
To change the bulbs, I sprayed the headlight retaining ring with WD40 first. Then after getting it apart, cleaned it off with soap and water.
Old 01-27-2011, 04:12 PM
poorman212's Avatar
I've seen the ring in the aftermarket (AZ, NAPA, CARQUEST, ECT). The dealer might also carry them.
Old 04-05-2013, 08:06 PM
Easy Duzit's Avatar
I just went through this too. Wound up breaking the locking ring. Only $5 for a new one through the dealer but it's a special order part. Won't be in for a few days. So right now the bulb is being held in place by duct tape lol.
Old 04-06-2013, 12:28 AM
holmesnmanny's Avatar
Everyone is not completely and totally careful will break the locking ring. I did this the very first time I tried replacing my bulb on the first Accord I had. Now I have to be really careful and spray the **** out of em when I try to replace mines.
AhhNickk
11-09-2009 04:15 PM
waggontrainer
Lighting
06-05-2008 03:26 PM
steven_b_03
02-25-2008 04:32 AM
vtec26
03-01-2007 05:28 PM
ttvegas2002
08-25-2005 06:54 AM
Quick Reply: 92 Accord EX - How to change front headlights?
