Rear end creaking
They call me the part of a womans vagina that causes pleasure.
Rear end creaking
I don't post here often, but i frequent the sub forum to learn.
I have a 99 DC4 w/ Koni/GC set up, F&F rear LCAs, ASR 24mm sway bar + sub frame brace + spherical end links.
Recently, when traveling slowly (entering/exiting my drive way for example) and the chassis is forced to twist a little, the right rear section of the car "pops". Its sufficient to the point that i can feel the "pop" right through the rails of the seat.
As far as i can tell I have installed everything correctly, I have double checked to make sure that the sub frame has not cracked/torn, not bolts are loose/sheared off. Nothing appears to be out of whack.
I have had a new set up installed for about 6 months now, and up until a couple weeks ago it was problem free. However, I have noticed that sometimes the right rear of the car feels "softer" than the left rear. I do not track/abuse this car in any way, but i do from time to time stretch its legs on some twistys. Could the sway bar be too big and causing too much stress? Are my end links not set up right? I am in no way an expert of suspension, but I am not a moron by any means when it comes to cars.
Here are a couple pics for reference so anyone with a keen eye can pick out something that looks out of whack...any input/suggestions would be GREATLY appreciated. Please help me, its driving me insane/scaring the hell out of me.
-Garrett
These were taken with both rear wheels off the ground, I can provide more/better pictures if anyone has any suggestion.
-Garrett
Re: Rear end creaking
what can I do to stop/prevent this? grease the hell out of them? That white stuff is not metal shavings/dust, its white lithium grease that i already tried to get it to stop
Also, if i use the other hole in the sway bar that is available will that stiffen the sway bar or soften it?
-Garrett
-Garrett
-Garrett
-Garrett
Also, it's been reccomend NOT to greese them. Dirt and **** will stick to the greese, and could casue the endlinks to fail quicker. F7 reccomends spraying them with WD40 to keep clean.
It could be your lca bushings as well. Try disconnecting your endlinks first and if the the noise continues install your oem lca's
Thank you all for replying to this thread, you have helped a lot already. Can anyone tell me if the other set of holes will stiffen or soften the sway bar's rigidity?
There was a special sort of grease that they came with, and I did apply some when installing. I will take some compressed air to them and clean them out once I remove them and WD40 them.
Will my car corner like **** with out the end links? I essentially wont have a sway bar at that point correct?
Thats what I thought too, I inspected everything on the LCAs and they look brand new still and show no signs of wear. Also, will my OEM LCAs work with my sway bar/end links?
You can't, It's just what the endlinks do. I have sphericals front+rear, so I know exactly what you're talking about. lol
good to know
good to know
What endlinks are they? I forgot to ask.
My blox endlinks came with noithing except the hardware.
If you remove the endlinks, yes the car will behave differently then it does now. But, you really only need to pop them off and go for a quick cruise.
Yes, OEM lower control arms should work with no problems. I use OEM control arms.
generaly any extra holes in the sway bar, or even the control arms will make the bar stiffer, or softer.
they are end links that came with the ASR sway bar/sub frame brace kit.
Pompiuses
09-01-2021 10:39 AM
EL-Driver
08-07-2002 12:20 AM
