98-99 CL & 98-02 Accord OBD2B ECU pin-out
Old 06-03-2010, 07:03 AM
crx_91si's Avatar
Default 98-99 CL & 98-02 Accord OBD2B ECU pin-out
This is a OBD2B ECU Pin-out for the 98/99 Acura 2.3 CL, should be exactly the same for 98-2002 4cyl Accords.
mike
Old 01-18-2012, 09:45 AM
OTOKOTO-TSOI's Avatar
Default Re: 98-99 CL & 98-02 Accord OBD2B ECU pin-out
Thanks for the Info - this is what I needed for a JDM F20B swapped on the Accord 98 EX model Sedan
Old 01-19-2012, 10:20 AM
Accord(ing)2me's Avatar
GREAT THREAD
Last edited by It Wasn't Me; 01-20-2012 at 05:48 PM. Reason: No need to quote the original post.
Old 11-23-2012, 02:13 PM
adelara's Avatar
Most useful indeed ! Thanks.
Old 12-02-2013, 07:59 PM
mahmood khan's Avatar
many thanks great informations
Old 03-02-2020, 07:21 AM
Gerald Anderson's Avatar
my problem is this manual connector at shock tower does not match
manual connector has 7 pins and auto has 12 pins which i found a few and am stuck
these wire left out maybe VSS wire in this cause that does not work reverse lights dont work and vtec i think i need help i prefer learning to help my self so i can help others so i chose DIY with help from others
Old 08-19-2020, 09:06 PM
Contralto91's Avatar
Great thread thank you.
After many parts replacement (TPS, MAP, Injector, distributor, plug, plug wire, compression test and some more) today I found the culprit is an intermittent issue on middle-green white cable on MAP socket.
Question: can I safely rewire both 1. from MAP socket to body ground and 2. From ECU pin to body ground?
Thank you.
Accord S84, 2001 Matic
Old 09-08-2021, 04:23 PM
Taylor Woollen's Avatar
Hey man I know this thread is over a year old, but I'm such at the same spot as you were. I'm trying to swap harnesses in a 97 to the harness used on a f23a1 but don't see any pin outs for those two grey connectconnector information on your solution would be greatly appreciated
97 style plugs newest the fuse box
97 Again
98-00 ish that fit f23a1 harness
F23a1 plugs
Any help would be greatly appreciated, I posted this question in my thread I started when I first began this swap journey. Like I said any information would be appreciated.
Old 01-24-2022, 08:32 AM
Smokeymcweedii's Avatar
97 Again
F23a1 plugs
Did you ever figure this out? Doing a swap from auto to manual on a 02 my harness is from a 01 but c102 is different one is square one is rectangle? C101 and everything else plugged up fine
Billy_Bob
12-22-2007 05:01 PM
fineAccord
04-03-2006 05:16 PM
joshb_
08-09-2005 10:45 AM
paulzy
07-15-2001 11:53 PM
Quick Reply: 98-99 CL & 98-02 Accord OBD2B ECU pin-out
