brakes making hissing sound when braking
Old 06-12-2011, 09:08 PM
swizz977's Avatar
Default brakes making hissing sound when braking
what would this mean everytime i brake i hear a hissss
Old 06-12-2011, 09:48 PM
virgineg6's Avatar
Default Re: brakes making hissing sound when braking
It means you need to check your brakes and possibly replace your pads
Old 06-13-2011, 04:25 AM
swizz977's Avatar
i just di all that
Old 06-13-2011, 04:47 AM
swizz977's Avatar
oh and it only hisses when im rolling n press the brakes not when im already stopped
Old 06-13-2011, 04:48 AM
The Grumpiest
grumblemarc's Avatar
Talk about lack of info.
Are you sure it's a hissing sound and not a light grinding noise?
Old 06-13-2011, 04:57 AM
swizz977's Avatar
no its deff hissing just replaced all the brakes too
Old 06-13-2011, 05:09 AM
swizz977's Avatar
also my pedal is very soft and mushy
Old 06-13-2011, 05:11 AM
Canuckian
Lugzilla's Avatar
Bleed your lines several times to get all the air out then come back with an update.
Old 06-13-2011, 05:18 AM
Ek Forever y0!
Libertariat's Avatar
Did you use brake caliper grease on the back of the pad when you installed them?
Old 06-13-2011, 05:25 AM
swizz977's Avatar
not sure but i had to get new calipers in the back
Old 06-13-2011, 05:27 AM
The Grumpiest
It's a yes or no question. You either did or did not. If you did not, which you probably didn't, that would most likely be the cause of the "hissing".
Old 06-13-2011, 08:31 AM
swizz977's Avatar
the hissing is coming from the rear brakes
Old 06-13-2011, 08:40 AM
Ek Forever y0!
Old 12-22-2011, 06:58 AM
ludedude48's Avatar
My wife's TL3.2 is doing the exact same thing. Its not the rear brakes. It sounds more like someone is letting the air out of a tire - and its coming from under the steering column.
Old 12-22-2011, 07:25 AM
purgat0ry's Avatar
Did you bleed the lines after the fact?
Make sure you installed everything properly.
Old 12-22-2011, 07:42 AM
MonkeyBoy668's Avatar
Icon3 Re: brakes making hissing sound when braking
Check the dates, ludedude48 is a necroposter. And he's asking about a problem with a TL in the 92-00 Civic/Del Sol forum.
Old 01-25-2014, 05:32 PM
swizz977's Avatar
where exactly are you supposed to put the brake grese
Old 01-25-2014, 05:36 PM
I never narc'd on nobody!
NotARaCist's Avatar
2+ year old thread...for a question that Google can answer. Don't do that. Rear of the pads, and on the caliper sliders.
TonyBlaz
02-03-2009 11:13 AM
highwayman
08-08-2005 07:12 AM
Lazydsm
12-09-2003 08:35 PM
See Are X
06-01-2003 02:51 PM
DeafNgari
04-20-2003 08:51 AM
Quick Reply: brakes making hissing sound when braking
