93 civic - making weird noise while in reverse
i have a 93 civic with a ls motor
heres the issue, the front end is being redone slowly, so far i have done inner and outer tie rods and all new lca and uca bushings. now for the noise, when i got to reverse or turn in reverse, you hear this weird whine and grind. stops right when i stop. only does this in reverse and when i make turns at low speeds. prolly cant hear it while im going cause the car shatters alot still.
anyone got a clue what it maybe? i was thinking my axles...
Re: 93 civic - making weird noise while in reverse
Id replace the wheel bearings next. The axles usually click when you turn and accelerate at the same time.
CaptRexKramer
09-27-2014 05:39 AM
