cracked exhaust manifold?
what causes an exhaust manifold to crack? would it be something thats wrong with the car internally that causes it to crack? or just the general heating and cooling over time
Re: cracked exhaust manifold?
is the manifold your talking about the ones on the dx models? thats a common problem most ek's with the stock manifold have over the years of use. my manifold on my hatch was cracked when i removed the heat shield. no need to worry.
srry if this doesnt answer your question.
After a while, you may kill your O2 sensor. That will cause it to run rich, which will eventually damage your cat and kill your spark plugs, which will hurt the performance of the engine. Running rich can also eventually "wash out" your cylinder walls, causing abnormal wear on the piston rings.
I've been driving my car with a cracked manifold for over a year; no idea exactly how long because my heat shield was covering it. It's cracked right between the runners, and into the O2 sensor bung. My check engine light just came on about 4-5 months ago; so at least 6 months after I noticed the crack.
You're pretty much guaranteed to fail emissions, because of the false readings it is going to give the O2 sensor.
Sol to Sol
You will also burn your exhaust valves there.
My dads car did, and its manifold was cracked between 2-3 and both cylinders had burned em up.
get a new one or buy an aftermarket one and eliminate the catalytic convertor thats what i did with my 97 ek hatch and used a o2 simulator to fool the ecu
hmmm im purchasing a car that has a cracked manifold, i need to take it home its about a 30 minute drive on the freeway, would you guys say its safe to do so?
Its normal for a car that age to crack the exhuast manifold and not an indicator of other problems. There's bigtime thermal stresses in an exhaust manifold and it's made of shitty cast iron. Over time it cracks. Depending on how big the crack is there's either no effect or like everyone else said it will crap out your HO2S and screw up A/F ratio and all kinds of crap from there. But driving just long enough to get it home to fix it is nothing to worry about.
would jb weld be strong enough to patch it just for now? i used jb weld once before wasnt as strong as everyone made it out to be... :/
If I'm not mistaken, JB Weld isn't meant to deal with nearly that much heat, so it'd probably melt off or even catch fire.
interesting.. when I had my d16y7 I also noticed that I had a crack on the header.. this should have been a recall but us Hondaphiles just swap the motor and header anyways
Hell, I don't even know if he still has the car lol
But why did you bump over a year old thread?
Well mine just came up cracked recently & I was searching for related threads. Jeez this happens quite a lot I see! Just sucks big time for us Cali folks! I wish I could just do the EX swap stuff
Why can't you swap to the Y8 stuff?
I would still talk to the dealer, and just see what they can do for you.
Can't do the Y8 stuff coz the Stupid California smog bullshit! Sometimes i wish i could just move to another state! Too much bullshit in Cali! As long as it burns clean thru the tail pipe is all what should matter... I'll try to talk to some dealers
So, you can't do the EX header swap and add the new catalytic converter and midpipe?
I did the same to mine years ago and it still passes inspection with flying colors
If aftermarket headers can pass why can't a OEM for a different car?
Hmm...I hadn't thought about it, but this might be what's going on with my '90 Accord. The manifold has a small crack, and that cylinder's exhaust valves are screwing up.
AFAccord
04-28-2017 11:09 AM
RACEPAK
11-25-2005 01:11 PM
