d16a1 specs?
Old 03-24-2009, 08:06 PM
dame-ningen's Avatar
Default d16a1 specs?
i cant seem to find any definite specs on this engine. i can get one for 75$ and im just seeing if its worht buying. thanks in advance, please help...
Old 03-24-2009, 08:32 PM
newtron63h's Avatar
Default Re: d16a1 specs?
113hp@6250 99tq@5500 9.5:1
Old 03-24-2009, 09:04 PM
New User
RedNuckles9's Avatar
what kinda vehicle you putting the possible d16a1? My 89 integra comes with it stock its a tourqe monster i love it
D16A1
Found in:
1986-89 Acura Integra (USA)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Valvetrain : DOHC (? valves per cylinder)
Fuel Control : OBD-0 MPFI
1986-1987
Compression : 9.3:1
Power : 113 hp (84.3 kW, 115 ps) @ 6250 rpm
Torque : 99 ft·lbf (13.7 kg/m, 134 Nm) @ 5500 rpm
Piston Code: PG6
1988-1989
Compression : 9.5: 1
Power : 118 hp (88.0 kW, 120 ps) @ 6250 rpm
Torque: 101 ft·lbf (14.0 kg/m, 137 Nm) @ 5500 rpm
Piston Code: P29 (Equivalent to PM7)
info from wikipedia
Old 03-24-2009, 09:21 PM
newtron63h's Avatar
what about 99 or 101ft/lbs is a monster? im pretty sure that puts it in the kitten range. my 86 Jetta turbodiesel made 92ft/lbs, it certainly was not a monster. it just made more racket doing it.
Old 03-24-2009, 09:48 PM
New User
so tourqe monster is overdoing it but a 20 year old engine with no power adders laying down a little rubber does fine by me
Old 03-24-2009, 09:53 PM
newtron63h's Avatar
ok, just making sure
Old 03-24-2009, 10:27 PM
cool thanks alot
so its worth the 75 bucks?
can i put a single cam vtec head on it?
Old 03-24-2009, 10:45 PM
en00be's Avatar
lol
kitten range
Old 03-24-2009, 10:59 PM
newtron63h's Avatar
for 75, what can it hurt.
matt94z
04-21-2009 10:48 PM
joey funk
06-19-2007 02:52 PM
civic_minded1987
Honda Civic (2001 - 2005)
40
11-22-2006 03:53 PM
Quick Reply: d16a1 specs?
