99 civic OEM foglight wiring!
Old 03-07-2009, 12:33 PM
I serve phở for my babies
ohsnapzafingcu's Avatar
Default 99 civic OEM foglight wiring!
hey guys i bought a complete OEM foglight kit for my 99 civic
the question is, what do i need to do in order for me to turn on my foglights before i turn my headlights on?
right now i'm using all the OEM brown connectors to power my foglights, if someone can link me to the how-to or DIY thread that'd be great!
p.s. this new search engine sucks!
Old 03-07-2009, 12:51 PM
Arthas's Avatar
Default Re: 99 civic OEM foglight wiring!
Its possible to do it with your OEM fog light wire harness. Check the FAQ for that.
But in my opinion;
-Its complicated.
-Its known to blow fuses.
-Its too much work.
-Your fogs turn off when you high beam.
Do what I did. I bought a $20 harness from Pep Boys. It comes with COMPLETE 12v wire kit, relay, switch (can be wired up to OEM switch), zip ties, fuse, etc etc.
What it does, is power up your fog lights through ANY 12v connection, then it has an extra wire from the relay in which you connect to your parking lights. So in order for the fogs to get power, the relay has to allow it, and the relay allows it when it gets the current from the corner lights.
If you do this, you can;
-Allow your fogs to come on with your parking lights (looks sick).
-Your fogs blink when you enable your alarm.
-Your fogs work independently from high beams.
Glad to be of help!
Old 03-07-2009, 01:03 PM
hazard2o9's Avatar
http://www.jimmmmmmmah.com/Install/H...g%20Lights.htm
Old 03-07-2009, 02:59 PM
The Collin's Avatar
Bryson, still need help with this?
Old 03-13-2009, 08:19 PM
thanks for the bump guys.. and COLLIN! but that link ^^^ is what i used.. works perfect!
Old 03-13-2009, 10:38 PM
b-series-em1's Avatar
fog light later on your gonna regret it best of stock bumper but yes if you still want the fog light don't connnect it with the head lights thats UGLY hide your wiring close to fender connect pug with fuse to allow fog light to come on only when ignition is on or on ac look for oem fog light hook up on google.
dapdabbin
11-22-2012 12:40 PM
superchargedY8
Lighting
04-21-2009 10:15 AM
Dynasty21
04-09-2008 11:36 AM
marc-111
26
01-15-2005 08:55 PM
The Poopsmith
05-20-2003 11:07 AM
Quick Reply: 99 civic OEM foglight wiring!
