B16 Tranny and Oil Capacities please
I need the manual transmission (transaxle if you want to get technical) capacity for a B16A, S4C in particular.
I need the oil capacity for a B16A. I've heard 4 quarts, I've heard 5, which is it?
This is all I need, thanks.
Re: B16 Tranny and Oil Capacities please
hey dood,
i think it should be 3.5-4 litres of oil for the motor (check the dipstick after 3.5 is poured in).
the tranny fluid should be about 2-3 bottles. fill it till it starts to come out of the hole
Here in the US it is about 3.5-3.9 Quarts. I usually pour 3.5 and then wait a while before I check the oil level to see if it needs more.
Thanks guys. I primarily wanted to know the tranny capacity to know if I should buy 2 or 3 quarts, sounds like 3.
(US quarts)
engine oil:
engine overhaul capacity - 5.1 quarts
oil change with filter - 4.2 quarts
oil change w/o filter - 3.9 quarts
transmission:
overhaul - 2.4 quarts
drain/refill - 2.3 quarts
EDIT: fixed the tranny capacity, thanks jdm602
engine oil:
transmission:
factory service manual
it's definitely believable... i know that a D-series manual tranny is also 1.9 quarts for drain/refill.
gsxr
08-21-2002 03:53 AM
