ignition output signal CEL #15
Old 11-06-2008, 03:43 PM
obuhmyuh's Avatar
Default ignition output signal CEL #15
hey guys i had a code 9 the other day CYP sensor (cyl 1 sensor), so i bought and installed a new dizzy from AZ and i was driving home and my car just shut off and a code 15 popped up. I think there may be a wiring problem near my ecu, so i checked those wires out and fixed a couple.
Cliff notes:
95 del sol si (jdm sohc vtec JDMd15b obd1)
car wont start (but will everyonce in a while when i tinker with the wires but shuts off
CEL #15 ignition output signal
anyone have some expertise?
Old 11-07-2008, 01:19 PM
obuhmyuh's Avatar
Default Re: ignition output signal CEL #15 (obuhmyuh)
bump
Old 11-07-2008, 01:31 PM
Former User's Avatar
Here's where to concentrate:
1) The igniter may be bad.
2) The Yel/Grn wire between the igniter and ECU may be bad (open or short).
3) The Blk/Yel wire between distributor 2P connector and ignition switch may be bad. There should be battery voltage with the key turned to ON(II).
Old 11-07-2008, 01:34 PM
obuhmyuh's Avatar
Default Re: ignition output signal CEL #15 (RonJ@HT)
yeah all of my wires are hacked to bits around that area by my ECU. I tried using a different ECU as well...
sounds like im going to need a mutimeter, i checked for power at the yellow/green wire using a lightbulb and ground and it looks like theres power there (maybe insufficient though???), i literally had just replaced the dizzy when this **** happened and i was driving away from autozone, so im not thinkin its the dizzy too much since its new...
Old 11-08-2008, 01:06 AM
obuhmyuh's Avatar
ttt
Old 11-09-2008, 07:45 AM
obuhmyuh's Avatar
bumppp
Old 11-09-2008, 04:54 PM
LS94tegra's Avatar
hey did you ever figure this out? my buddy has the same problem but he has no spark, and throwing code 15.
Old 11-09-2008, 11:46 PM
obuhmyuh's Avatar
Default Re: ignition output signal CEL #15 (LS94tegra)
not yet, could use some help though...
Old 07-16-2009, 03:31 PM
moknoy's Avatar
I am having this problem now with my civic. Necro but answers will be great!
Old 07-30-2009, 09:28 PM
hialeahzbg's Avatar
i have the same problem....ive changed the dizzy and ecu and still...im getting no spark...
Old 07-30-2009, 09:35 PM
Is the CEL on?
Does the Blk/Yel wire in the distributor have battery voltage with the key in ON(II)?
Does the Yel/Grn wire running between the igniter unit and ECU have continuity? What voltage does this wire have at the igniter unit with the key in ON(II)?
Old 07-31-2009, 09:11 AM
hialeahzbg's Avatar
Originally Posted by RonJ@HT
Is the CEL on?
the cars at a friends house and hes working on it but he hasnt been about to figure anything out...ima text him what u wrote...what if the blk/yel wire in the dizzy has voltage?
Old 07-31-2009, 09:18 AM
hialeahzbg's Avatar
ok he said it does not have power...
Old 07-31-2009, 09:25 AM
No power with the key in ON(II), right?
If so, the Blk/Yel wire is broken somewhere between the distributor connector and the ignition switch OR the ignition switch is bad. Have him check those two possibilities.
Old 07-31-2009, 10:40 AM
hialeahzbg's Avatar
AwEsome... I'll have him look at it.. Anything else it could be?
Old 07-31-2009, 10:46 AM
What year? Did he already inspect the Blk/Yel wire pins in the distributor connectors for damage? Does the windshield washer motor work?
Old 07-31-2009, 11:34 AM
hialeahzbg's Avatar
It's a 95 rhd sir eg6
Old 07-31-2009, 11:39 AM
Okay. Any answers for the other two questions?
Old 07-31-2009, 11:42 AM
hialeahzbg's Avatar
He's gonna get home like 3 hours... I texted him wat u wrote...
Old 07-31-2009, 11:43 AM
hialeahzbg's Avatar
Can u pm me ur number so we can call u?
Old 08-01-2009, 09:52 PM
hialeahzbg's Avatar
Thanks!!! it fixed my problem!!!
Old 08-01-2009, 10:04 PM
Great. What was the solution?
Old 08-03-2009, 06:49 AM
hialeahzbg's Avatar
bly/ylw was ripped somewhere between the ecu plugs...
Old 12-28-2009, 10:37 AM
eaddagwan's Avatar
good stuff, im having the same issue here, hopefully i can see about just replacing the black/yellow wire all the way through. any advise going into it?
Old 06-30-2010, 10:12 AM
killa94's Avatar
hey i have the same problem...ive checked the blk/ylw wire and it has a current but am not sure how to test the igniter
Quick Reply: ignition output signal CEL #15
