How to convert to 5 lugs
Old 08-13-2008, 11:55 AM
dragonkx's Avatar
Default How to convert to 5 lugs
I have a 95 gsr, it has a 4 lug and i want to convert it to 5 lug so i can put on type r rims. do I buy a conversion kit or get a like a rsx disks, etc.
Old 08-13-2008, 12:06 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: How to convert to 5 lugs (dragonkx)
Most people just weld on the new hub and call it a day
Old 08-15-2008, 04:52 PM
NeverLift's Avatar
hmm...how do you really do it? i'm trying to convert my 4 lug into a 5 lug without spending as much money on a ITR conversion.
It be nice if someone just listed the parts I needed.
Old 08-15-2008, 05:56 PM
BlueIntegraBoy's Avatar
Default Re: (NeverLift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeverLift &raquo;</TD></TR><TR><TD CLASS="quote">hmm...how do you really do it? i'm trying to convert my 4 lug into a 5 lug without spending as much money on a ITR conversion.
It be nice if someone just listed the parts I needed.</TD></TR></TABLE>
By the time you buy all the parts new, you'll end up paying just as much as the conversion, if not a little more. On the plus side, everything will be new.
1. Hubs (fr and rr)
2. Calipers brackets (ft and rr)
3. Calipers (fr and rr)
4. Wheel bearings (ft)
5. Lower balljoints (might as well)
6. Rotors (fr and rr)
7. Pads (ft and rr)
8. Rims
Old 08-16-2008, 01:44 PM
NeverLift's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
1. Hubs (fr and rr)
7. Pads (ft and rr)
8. Rims</TD></TR></TABLE>
but i heard there is an easier way. like an "adapter" or some sort. is there? if so, explain.
Old 08-18-2008, 12:23 PM
NeverLift's Avatar
anyone?
Old 09-16-2008, 09:17 AM
NeverLift's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeverLift &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
Old 09-16-2008, 10:06 AM
EJ1_Ex's Avatar
you can also purchase prelude 5 lug conversion. I believe they are the same lug pattern. Might be cheaper to go that way.
Old 09-16-2008, 10:13 AM
NeverLift's Avatar
Default Re: (EJ1_Ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_Ex &raquo;</TD></TR><TR><TD CLASS="quote">you can also purchase prelude 5 lug conversion. I believe they are the same lug pattern. Might be cheaper to go that way. </TD></TR></TABLE>
i dont want to spend more $300. as i stated before is there any type of "adapter"?
Old 09-16-2008, 11:13 AM
Fast Frankie's Avatar
Here is someone who offers a 4 - 5 lug adapter. Not really in your price point but I've heard there are cheaper. You should search around...
http://www.skulte.com/index.php/cPath/21
Old 09-17-2008, 06:50 PM
be professional
Targa250R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonkx &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 gsr, it has a 4 lug and i want to convert it to 5 lug so i can put on type r rims. do I buy a conversion kit or get a like a rsx disks, etc.</TD></TR></TABLE>
You can piece it together easily with new parts, or you can buy a conversion kit full of used parts needing replacement for roughly the same amount of money. Your choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">Most people just weld on the new hub and call it a day </TD></TR></TABLE>
You don't weld anything.
You don't use Prelude/Accord hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeverLift &raquo;</TD></TR><TR><TD CLASS="quote">i dont want to spend more $300. as i stated before is there any type of "adapter"?</TD></TR></TABLE>
Hub adapters should not be used. They cause more headaches than doing it the right way. If you don't want to spend more than $300, then you cannot afford to do this without half-assing it so I suggest that you forget it altogether.
zhen_fai
10-08-2008 09:18 AM
Jibin
Honda Civic (2001 - 2005)
07-25-2008 08:14 AM
naeghatch
Suspension & Brakes
10-23-2007 06:31 PM
civic_eg-o
02-11-2006 01:49 PM
guywitaDA
07-13-2005 06:29 PM
Quick Reply: How to convert to 5 lugs
