94 accord ex ecu pin chart?
Old 08-31-2008, 04:18 PM
hon2984's Avatar
Default 94 accord ex ecu pin chart?
anybody know a link to a pin out chart for either the 93 accord ex ecu or the 94 ex f22b1 ecu (POA)
ive read the FAQ threads and cant find anything
Old 08-31-2008, 05:27 PM
GhostAccord's Avatar
Default Re: 94 accord ex ecu pin chart? (hon2984)
94-95 Accord ECU
Pin - Description - Wire Colour
A1 - INJ1 - BRN
A2 - INJ4 - YEL
A3 - INJ2 - RED
A4 - VTEC SOL - GRN/YEL
A5 - INJ3 - BLU
A6 - O2 Heater ORG/BLK
A7 - Fuel Pump Relay - GRN/BLK
A8 - EMPTY
A9 - IACV - BLK/BLU
A10 - Engine Mount Control - GRN/WHT
A11 - EGR SOL - RED
A12 - Rad Fan Control - GRN
A13 - MIL - LTGRN/RED
A14 - Fuel Injection Air Control - WHT/YEL
A15 - AC Control - RED/BLU
A16 - ALT Control - WHT/GRN
A17 - EMPTY
A18 - FAS - BRN/WHT (TCM)
A19 - IAR Control SOL - ORG/GRN
A20 - PCS - RED/YEL
A21 - ICM1 - YEL/GRN
A22 - EMPTY
A23 - Power Ground 1 - BLK
A24 - Power Ground 2 - BLK
A25 - IGP1 (Power Source) - YEL/BLK
A26 - LG1 (Logic Ground) - BRN/BLK
B1 - IGP2 (Power Source) - YEL/BLK
B2 - LG2 (Logic Ground) - BRN/BLK
B3 - AFS A - WHT RED (TCM)
B4 - AFS B - GRN (TCM)
B5 - AC Pres Switch - RED/WHT
B6 - EMPTY
B7 - AT Gear Pos - lightLTGRN
B8 - Power Steering Pres Sw - GRN
B9 - STS - BLU RED (or BLK/GRN)
B10 - VSS - ORG
B11 - CYP Signal - ORG
B12 - CYP Ground - WHT
B13 - TDC Signal - ORG BLU
B14 - TDC Ground - WHT BLU
B15 - CKP Signal - BLU GRN
B16 - CKP Ground - BLU YEL
D1 - Voltage Back Up - WHT YEL
D2 - Brake Switch - GRN/WHT
D3 - EMPTY
D4 - SCS - RED
D5 - BARO OUT - BLU/WHT
D6 - VTEC Pres Switch - BLU/BLK
D7 - TXD/RXD - lightLTGRN RED
D8 - EMPTY
D9 - ALT FR Signal - WHT RED
D10 - EL (ELD) - GRN RED
D11 - TPS - RED/BLK
D12 - EGR Lift Sensor - WHT/BLK
D13 - ECT - RED/WHT
D14 - O2 Signal - WHT RED
D15 - IAT - RED YEL
D16 - EMPTY
D17 - MAP - WHT YEL
D18 - VREF - lightLTGRN/BLK
D19 - VCC1 (Provides Sensor Voltage) - YEL/WHT
D20 - VCC2 (Provides Sensor Voltage) - YEL BLU
D21 - SG1 (Sensor Ground) - GRN/WHT
D22 - SG2 (Sensor Ground) - GRN BLU
Old 08-31-2008, 10:42 PM
hon2984's Avatar
Default Re: 94 accord ex ecu pin chart? (GhostAccord)
A B D
12345678910111213 ........... .........
14151617181920212223242526
is how it would be numbered? if i was looking at the ECU.
Old 09-01-2008, 03:09 AM
Oh yeah, sorry about that.
On the OBD1 ECU's the numbers are Odd numbers on top & even on bottom.
Old 09-01-2008, 06:03 AM
hon2984's Avatar
much appreciated ghost!
by the way i checked out your ITB thread. Very nice!
how did you find out that you could use those throttle bodies from a suzuki?
i know that you dont have to worry about vtec kicking in because of a CEL
but how do you keep your car from going into limp mode because you dont have an IACV?
Old 09-01-2008, 07:28 AM
No problem
As for the throttle bodies, you can use pretty much any throttle body. Be it single, double or quad. As long as it fits your car, you have a way to feed it fuel and tune it.
The ECU ROM (program/basemap) that I will be using will not be looking for an IACV. The two rom editors that I have used, Crome & eCtune, have the ability to disable a number of items such as; IACV, VTEC, IABs, & A/C. Therefore your ECU doesn' throw a CEL if thoes items are removed from your car.
Modified by GhostAccord at 12:33 PM 9/1/2008
Old 11-06-2009, 07:52 AM
jthrasher1's Avatar
hey do you know ware i can find this same diagram for a 96 accord lx f22b2 poj lo1 ecu i need this very badly pleae help...
Old 11-06-2009, 08:52 AM
96-97 POA & POJ / P0B
Pin Description Wire Color
A1 INJ4 YEL
A2 INJ3 BLU
A3 INJ2 RED
A4 INJ1 BRN
A5 SO2SHTC ORG/BLU OR ORG/BLK
A6 PO2SHTC ORG/BLK
A7 ESOL
A8 BLANK (F22B1 = VTSol GRN/YEL VTEC solenoid)
A9 LG1 BRN/BLK
A10 PG1 BLK
A11 IGP1 YEL/BLK
A12 IACV BLK/BLU
A13 MCS GRN/WHT
A14 BLANK
A15 PCS RED/YEL
A16 FLR GRN/BLK
A17 ACC RED/BLU
A18 MIL LT GRN/RED
A19 ALTC WHT/GRN
A20 ICM YEL/GRN
A21 BLANK
A22 LG2 BRN/BLK
A23 PG2 BLK’
A24 IGP2 YEL/BLK
A25 IARSOL ORG/GRN
A26 BLANK
A27 FANC GRN
A28 2WBS
A30 BLANK
A31 BLANK
A32 BLANK
Automatic Transmissions use the ECUs B connector
B1 BLANK
B2 BLANK
B3 SHA BLU/YEL
B4 LCB GRN/BLK
B5 LCA YEL
B6 BLANK
B7 BLANK
B8 ATPD GRN/BLU
B9 BLANK
B10 BLANK
B11 SHB GRN/WHT
B12 ILU WHT/GRN
B13 D4 IND BLU/RED
B14 NMSG WHT/BLU
B15 NM ORG/BLU
B16 ATPR GRN/RED
B17 ATP2 GRN/YEL
B18 ATP1 LT GRN/WHT
B19 BLANK
B20 BLANK
B21 BLANK
B22 NCSG BLU/YEL
B23 NC BLU/GRN
B24 ATPD4 LT GRN/BLK
B25 ATPNP LT GRN
C1 BLANK
C2 CKPP BLU
C3 TDCP GRN
C4 CYPP YEL
C5 ACS RED/WHT
C6 STS BLU/RED OR BLK/GRN
C7 SCS RED
C8 K-LINE LT GRN
C9 BLANK
C10 VBU WHT/YEL
C11 BLANK
C12 CKPM WHT
C13 TDCM RED
C14 CYPM BLK
C15 BLANK
C16 PSPSW GRN
C17 ALTF WHT/RED
C18 VSS ORG
C19 BLANK
C20 BLANK F22B2 = C20 PFSW BRN
C21 BLANK
C22 BLANK
C23 BLANK
C24 BLANK
C25 BLANK
C26 BLANK
C27 BLANK
C28 BLANK
C29 BLANK
C30 BLANK
C31 BLANK
D1 - TPS (RED/BLK)
D2 - ECT (RED/WHT)
D3 - MAP (WHT/YEL)
D4 - VCC1 (YEL/WHT)
D5 - BKSW (GRN/WHT)
D6 - BLANK
D7 - PHO2S (WHT/RED)
D8 - IAT (RED/YEL)
D9 - EGRL (WHT/BLK)
D10 - VCC2 (YEL/BLU)
D11 - SG2 (GRN/BLU)
D12 - SG1 (GRN/WHT)
D13 - SHO2SG (GRN/BLU or RED/WHT)
D14 - SHO2S (WHT/RED)
D15 - PTANK (GRN/RED)
D16 - ELD (GRN/RED)
Old 11-06-2009, 10:08 AM
jthrasher1's Avatar
ok thanks but now another question the reason i need this is im trying too hook up an apexi neo afc controler all these abreviations arent really helpin i got power and ground now need to figure whick wire is rpm and throtle..... also arent you missing section d on pin out chart
Old 11-06-2009, 11:12 AM
Sorry forgot to copy the D section. I made the correction/edit to above post.
The RPM signal output for fuel hacks does not connect to the ECU. I think the RPM signal wire you are looking for is the BLU wire that goes from the distributor to the back of the gauge cluster. It is the tach rpm signal wire.
The throttle signal aka TPS or throttle position sensor is pin D1 (RED/BLK)
Old 11-06-2009, 11:29 AM
jthrasher1's Avatar
thank god for people like you lol this did the trick allset now thanks again.... and im probly gonna use the blue wire but my buddy told me i could use the crankshaft position sensor is he right or wrong if ya know lemme know thanks...
Old 11-06-2009, 12:15 PM
If you are looking for an ECU wire to tap into the Neo diagram that I found shows that you can use the ICM signal from Pin A20 for the RPM signal.
Old 01-22-2010, 06:38 PM
New User
tat2me's Avatar
hi, i have the 97 cl v6 and i need the pinout for it, can any one help, all i can fined is the f model and the f is not the same as the j. thanks in advance
Old 01-22-2010, 06:58 PM
be professional
Targa250R's Avatar
http://www.helminc.com/helm/product2...0EL&itemtype=N
http://www.helminc.com/helm/product2...803&itemtype=N
http://www.helminc.com/helm/product2...800&itemtype=N
Old 11-04-2014, 04:44 PM
edgar813's Avatar
I have a 94 accord ex f20b1 and my ac does not work I already checked fuses,relays,compressor,Freon,and every thing seems to be fin except the compressor relay that does not ground when I press the ac button I have 3 grounds instead of just 2 and I was thinking it can be my ecm or tcm. Can yall help me out pls
Old 11-04-2014, 06:31 PM
holmesnmanny's Avatar
When you ground the compressor does the compressor turn on ?
Old 11-05-2014, 06:09 AM
edgar813's Avatar
I applied current to it an it would turn on I didn't need to ground it cause its grounded to the engine
Old 11-05-2014, 08:52 AM
Global Moderator
tech8's Avatar
The problem can be an issue with either:
• Heater control panel
• Wiring
• A/C thermostat
• A/C pressure switch
• ECM/PCM
This is how the system works:
When you push the A/C switch ON, and the heater fan switch is in position 1, 2, 3, or 4, a “ground” input is provided to the ECM/PCM through the A/C thermostat and the A/C pressure switch. The A/C compressor clutch relay is grounded by the ECM/PCM. When energized, the relay allows battery voltage to energize the compressor clutch coil which then engages the clutch.
Although, the issue may be with any of the items I listed, many times on the 5th generation Accords, the A/C thermostat is the culprit. The thermostat probe is in between the fins of the evaporator. However, you should try to isolate the area of the issue first before replacing anything.
Old 11-09-2014, 04:51 PM
edgar813's Avatar
Thanks a lot and so the tcm does not have no do nothing with the ac?
Old 11-09-2014, 07:30 PM
Global Moderator
tech8's Avatar
The TCM does not control the A/C compressor clutch relay. Although you'll see the TCM as part of the A/C circuit diagram, the way the flow is:
1) When the A/C switch is ON and the heater fan switch is in position 1, 2, 3, or 4, a "ground" input goes to
2) the A/C thermostat, which then goes through
3) the A/C pressure switch, which then goes through
4) ECM/PCM, the ECM/PCM will then send a ground input to both the A/C compressor clutch relay and the TCM.
The TCM does not control the A/C compressor clutch relay. The ground input from the ECM/PCM to TCM looks like it will affect the transmission lock-up clutch when the A/C is ON.
bmayo3595
01-17-2015 05:11 AM
92hatchNC
01-14-2011 09:21 AM
90civic-racer
04-01-2003 04:34 PM
Quick Reply: 94 accord ex ecu pin chart?
