timing belt adjustment
Old 07-12-2008, 12:54 PM
danteisme's Avatar
Default timing belt adjustment
so my timing belt is pretty loose after replacing it, the water pump, and tensioner. there is almost and inch and an eight of deflection on the exhaust side. obviously that side will have the most slack cuz its the longest part without being on another pulley or whatever. i was reading the manual on how to adjust it, i just wanna make sure im understanding what they're saying. heres what it says
obviously take the vc off
1. set no.1 to TDC
2. roate the crankshaft 5-6 revolutions to set belt
3. then set no. 1 to tdc again
4. loosen adjustment bolt(tensioner) 1/2 turn
5. this is whre im slightly confused..it says rotate the crankshaft counterclockwise 3 teeth on the camshaft pulley. so im assuming i just rotate the crank til i count 3 teeth go by on one of the cams?
6. tighten bolt and done
Old 07-13-2008, 04:36 AM
stumpyf4's Avatar
Default Re: timing belt adjustment (danteisme)
You're correct, as you turn the crank slightly the cams add tension to the belt since they're trying to pushing open some valves.
Since your belt has been running for a while I would just do steps 3-6. It's pretty obvious if you do it right, belt will be nice and tight.
Suggestion, don't drive the car until you retension the belt.
Old 07-13-2008, 06:34 AM
ACTION JACTION's Avatar
Sometimes this method doesnt work as it didnt work for me so I had to do the coat hanger technique.
Take a metal coat hanger and make one end into a fish hook. Loosen the tensioner and then hook it with the coat hanger and pull up on it till you get enough tension, then tighten it.
Old 07-13-2008, 07:34 AM
letsdrive's Avatar
youre supposed to leave the tensioner bolt loose when you do the 5-6 rotations . Bring it back to tdc then tighten it then rotate it three teeth ccw, then you loosen it and youll see the slack tighten from the tensioner. then you tighten the tensioner bolt to 45 ft/lbs.
Old 07-13-2008, 04:08 PM
stumpyf4's Avatar
Default Re: (letsdrive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by letsdrive &raquo;</TD></TR><TR><TD CLASS="quote">youre supposed to leave the tensioner bolt loose when you do the 5-6 rotations . Bring it back to tdc then tighten it then rotate it three teeth ccw, then you loosen it and youll see the slack tighten from the tensioner. then you tighten the tensioner bolt to 45 ft/lbs. </TD></TR></TABLE>
Negative. Re-read your manual. Try rotating the crank with the tensioner bolt loose, guaranteed to skip a tooth or more.
Quote from the manual for tensioning the belt (1998 Integra page 6-9)
1) Remove the cylinder head cover.
2) Set the No. 1 piston at TDC
3) Rotate the crankshaft five to six revolutions to set the belt.
4) Set the No. 1 piston at TDC
5) Loosen the adjusting bolt 1/2 turn (180deg) only.
6) Rotate the crankshaft counterclockwise 3-teeth on the camshaft pulley.
7) Tighten the adjusting bolt to the specified torque.
8) After adjusting, retorque the crankshaft pulley bolt to 177Nm.
Old 07-13-2008, 05:35 PM
danteisme's Avatar
Default Re: (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah thats what i was thinking, i figured i'd wait to see what other people said first
Old 07-14-2008, 04:45 PM
letsdrive's Avatar
i meant have it tight. hands didnt write what brain meant.
Old 07-02-2009, 04:43 PM
New User
enriquediaz's Avatar
what way am i supposed to rotate the tensioner bolt to loosen it up? ive been trying for a long time to loosen up the belt to get in back onto the pulleys... but the more i do it the more the bolt gets rounded.
Old 07-03-2009, 08:29 AM
hmoobhero's Avatar
common rule. "lefty loosely" "righty tighty".
Old 07-17-2009, 02:41 AM
skhell's Avatar
Hi!
When we turn the crank pulley 3 teeth on the cam pulley, the belt gets more tensioned or less tensioned?
To understand better my question, imagine we would only loosen the adjuster bolt, and tightened it, the belt would be with more or with less tension that when rotating the cam 3 teeth?
Old 08-25-2009, 02:56 PM
New User
RicardoPTmax's Avatar
Hi...
I have found the timming belt a quite loose.
retightening as adivised in workshop manual created a grind sound in some of the pulleys... or water pump
then i did the same rotating only one teeth and the wierd sound decreased to bare nothing.
i mean... Retightening a belt that has 50k (km) on it... didnt work as expected
so i had to draw back and now even though the belt when cold vibrated a little it works straight when normal temperature...
i supose that this is water pump bearings going away... 160 k needing a new one
can you give any advise about this?
Thanks
PS: boas skhell tudo bem? lol tuga do catano.
Old 08-25-2009, 03:04 PM
New User
Originally Posted by skhell
Hi!
olá
quando rodas a cambota... a correia estica de um lado.. e do outro o tensor acança para a posição normal e é fixo ai ao aparafusar a porca.
mas isso é valido para correias novas apenas... n podes fazer os 3 dentes com uma correia usada. suponho.. pelo menos foi o que fiz
é normal que haja algum barulho durante primeira semana. ate que ela estique um pouco para o tamanho e tensao normal.
(english)
hi... when you turn the crankshaft the belt stretches in one side while in the other the tensioner pulley advances reduces it slack and when you tighten the bolt, it stays in the proper position.
thing is ------- that it is valid to new belts only.. old betls... cant do the 3 teeth must be less i guess... that what i did.
it is natural that some noise pulley might be heardable in the first week or so a until it streaches a bit to normal state.
Old 08-31-2009, 03:18 AM
skhell's Avatar
Originally Posted by RicardoPTmax
Hi...
Thanks
Maravilha, não sou o unico tuga por aqui eheheh
Well, I always thought that the procedure of setting the right amount of tension would apply to a old belt, after all, timing belts are not supposed to stretch over the time... Any way, your experience with this is very helpfull, thank you so much, that thing of rotating it only one tooth is a good idea, the problem is if it got with less tension than it should...
Old 09-21-2009, 12:10 AM
8OOSTED's Avatar
How do I get to the tensioner bolt? Do I have to remove the entire timing belt cover? My friends told me I could do it without removing all that but I can't figure out how.
PS: I have a 94' LS
Old 09-21-2009, 06:12 AM
danteisme's Avatar
PS: I have a 94' LS
its been a while since i did this, but i believe there is a plug in the timing cover you can pop out and gain access to the bolt. just dont over loosen it or you might be screwed.
ryanevansoh
04-22-2009 08:51 PM
B18C5_VTEC
11-02-2007 09:18 AM
89sparks
08-31-2007 06:27 PM
RoB316
04-06-2007 10:09 AM
Quick Reply: timing belt adjustment
