Honda S2000 Honda S2000
best s2000 turbo kit.... 2 choices
Old 03-04-2008, 08:42 AM
projektcivic's Avatar
Default best s2000 turbo kit.... 2 choices
ok... first of all... on a budget here... i want to start my turbo projekt.
Garrett Turbo Starter kit- $1500 shipped comes with:
1. Cast Iron turbo manifold (38mm wastegateflanged)
2. Authentic Garrett Turbocharger
T3 turbo inlet flange
.48 A/R Turbine housing
4 Bolt discharge
.42 A/R compressor housing
60 Trim
2.25” compressor outlet
2.25” compressor inlet
3. Turbonetics evolution 38mm Wastegate
3 interchangeable springs
Shims
Vacuum fittings
Vacuum line
4. Instruction manual
5. Oil lines
Oil feed tee correct 1/8th bnpt fitting
Steel braided high pressure feed and drain lines
AN fittings
6. Oil feed and Oil drain flanges
7. Downpipe flange and gasket
8. 38mm wastegate flange and gaskets
9. Oil feed and drain gaskets
10. Turbo inlet gasket
11. Downpipe bolts
12. Turbo bolts
13. Wastegate bolts
14. 1.5” u-bend for fabrication of wastegate dump
15. 2.5” u-bend for fabrication of downpipe
16. All necessary washers and lock washers
OOORRRRRRRRR.......
Godspeed Turbo kit- $2580 shipped
authentic turbonetics t3t4 turbo
-authentic rev hard s2000 cast turbo manifold
-authentic godspeed s2000 intercooler kit (with intercooler size 30x7.5x3) direct bolt on
-stainless steel 2.5 downpipe
-wastegate dump tube
-godspeed 38mm wastegate (7psi )
-intake with intake cone
-type-rs blow off valve
-oil line kit with all fitting (oil drain, oil feed )
which would be the better deal?
Old 03-04-2008, 08:45 AM
NoBottleJustThrottle's Avatar
Default Re: best s2000 turbo kit.... 2 choices (projektcivic)
I'll let someone else chime in about your options here...but a word to the wise: "Budget" and "Turbo" don't go well together.
Old 03-04-2008, 08:57 AM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projektcivic &raquo;</TD></TR><TR><TD CLASS="quote">ok... first of all... on a budget here... i want to start my turbo projekt.
which would be the better deal?</TD></TR></TABLE>
first of all. this isn't a civic.
do a little more research
Old 03-04-2008, 08:58 AM
Under_Pressure's Avatar
Default Re: best s2000 turbo kit.... 2 choices (NoBottleJustThrottle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoBottleJustThrottle &raquo;</TD></TR><TR><TD CLASS="quote">but a word to the wise: "Budget" and "Turbo" don't go well together.</TD></TR></TABLE>
and its for a S..... Save up do it right the first time no regrets
Old 03-04-2008, 09:01 AM
Default Re: best s2000 turbo kit.... 2 choices (Under_Pressure)
but heres the thing... there are cheaper non name brand kits out there.... im not going with them at all....
both of these name brands have REAL brands such as turbonetics, garrett, Tial, etc....
ive done my research and turbo'd several vehicles (civic, integra, 240, srt-4 bigger turbo, etc...)
Old 03-04-2008, 09:07 AM
* B A N N E D *
GRAF-FITI's Avatar
weren't you the dude who didn't even know how to install a cold air intake?
https://honda-tech.com/zerothread/2238871
Old 03-04-2008, 09:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projektcivic &raquo;</TD></TR><TR><TD CLASS="quote">but heres the thing... there are cheaper non name brand kits out there.... im not going with them at all....
and i'm supposed to be impressed, why?
if you know so much about what you are doing, why are you even asking for our help?
personally I think either kit is a waste of money. save up a little more so you can afford a real kit, or better yet, don't turbo your car. I'm tired of seeing retard's with "blowed" motors
Old 03-04-2008, 09:51 AM
papa5murf's Avatar
Both of the above kits are useless. If you're on a budget, then don't go boost. You've also missed ONE major key ingredient. ENGINE MANAGEMENT.
* B A N N E D *
GRAF-FITI's Avatar
Default Re: best s2000 turbo kit.... 2 choices (Techno Tonis)
you should be impressed that while he can't even install an intake, he knows EVERYTHING about turbo installs....
DUH
Old 03-04-2008, 01:38 PM
HondaKyle's Avatar
budget and turbo dont go along with each other. ive peaced my kit together and had discounts on parts from local shops. I think ive spent around 3,200 dollars and with out the discounts im sure it would be around 4,500 easily. There is a lot of little stuff people dont think about when boosting a car; do you know what a "missing link" is?
I Hope this isnt off ebay. In the forced induction thread a lot of those guys say they have made around 500-600 horse with the FMICs but All the other parts ive never heard any thing good about. Then again those guys will tell you its save to run your boosted car with no intercooler if you dont have the money for one.
Modified by HondaKyle at 2:49 PM 3/4/2008
Old 03-04-2008, 03:56 PM
A_P_1's Avatar
N/A is best
Old 03-04-2008, 08:29 PM
Y0N1P8T5R1F5A4T's Avatar
Default Re: best s2000 turbo kit.... 2 choices (A_P_1)
I'd go with GReddy.
Better safe than sorry.
Only sorry part is that, it's 60 to 80 to 100 more horsepower?
Correct me if I'm wrong.
Also sorry part is, it's $4,500.
From http://www.evasivemotorsports....50040
But it comes with <U>EVERYTHING!!!!!!!</U>
No dyno tuning.
Correct me if I'm wrong on that also.
Thank You.
Old 03-04-2008, 10:09 PM
Francesco's Avatar
your 2 choices are lame. save some more money up while you do more turbo research
Old 03-05-2008, 03:55 AM
HondaKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A_P_1 &raquo;</TD></TR><TR><TD CLASS="quote">N/A is best </TD></TR></TABLE> NA best is the dumbest thing you can say.... it makes no real power ever in any car compared to what it could make F-I. NA best is a joke
Old 03-05-2008, 04:39 AM
Default Re: best s2000 turbo kit.... 2 choices (Y0N1P8T5R1F5A4T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y0N1P8T5R1F5A4T &raquo;</TD></TR><TR><TD CLASS="quote">I'd go with GReddy.
No dyno tuning.
Thank You. </TD></TR></TABLE>
greddy kits are very basic, and carb legal...i believe...still doesnt mean they dont need to be tuned, they just use an e-manage, instead of a real ems.
but yes, for the op...greddy turbo kit would be a very good choise for him.
Old 03-05-2008, 04:49 AM
S2KILLA's Avatar
Location: Yeah IM from Jersey, big wup, wanna fight about, it, USA
the op needs this to go along with his intake:
guaranteed to make 25 HP...
thats if he can install the intake properly...
and if he does in fact install it, hes gonna need a "how to" to take it out and install his ebay special turbo...
Old 03-05-2008, 04:52 AM
papa5murf's Avatar
No dyno tuning.
Wrong. The map Greddy gives you is a simple basemap to get you to the tuner safely.
Old 03-05-2008, 09:38 AM
Honda-Tech Order of Merit
Chris.'s Avatar
Default Re: best s2000 turbo kit.... 2 choices (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">Both of the above kits are useless. If you're on a budget, then don't go boost. You've also missed ONE major key ingredient. ENGINE MANAGEMENT. </TD></TR></TABLE>
cheap, fast, and reliable... you can only have 2 at a time
Old 03-05-2008, 10:40 AM
b20integrapower's Avatar
Default Re: best s2000 turbo kit.... 2 choices (Chris.)
Eh..i dont know why he is getting knocked so hard.
I dont see what is so wrong with the second kit besides the wastegate and ems. Id dump that wg and get a tial though. Imagine if it got stuck closed. That would be fun for about 3 seconds.
Old 03-05-2008, 11:36 AM
92HB_HB's Avatar
Default Re: best s2000 turbo kit.... 2 choices (b20integrapower)
best budget kit would be one you piece together..
Old 03-05-2008, 12:47 PM
CXHATCHver2.2's Avatar
Default Re: best s2000 turbo kit.... 2 choices (92HB_HB)
I don't know why people insist on downgrading the S2000 in stock form by buying cheap ebay junk and throwing it on the car. Actually just go blow it up, then tell people the S2000's are junk. The ones that appreciate the car can go on living without hearing questions like "How do I drift my S2000?" or "will the Invidia exhaust drone at all?" OR "Which crap turbo kit can I put on my car?"
Oh and S2K + budget = sell it and go back to the civic
Old 03-05-2008, 12:51 PM
* B A N N E D *
GRAF-FITI's Avatar
Default Re: best s2000 turbo kit.... 2 choices (CXHATCHver2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHATCHver2.2 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know why people insist on downgrading the S2000 in stock form by buying cheap ebay junk and throwing it on the car. Actually just go blow it up, then tell people the S2000's are junk. The ones that appreciate the car can go on living without hearing questions like "How do I drift my S2000?" or "will the Invidia exhaust drone at all?" OR "Which crap turbo kit can I put on my car?"
Oh and S2K + budget = sell it and go back to the civic </TD></TR></TABLE>
well said...join the berlina mob...you'd fit right in
Old 03-05-2008, 12:55 PM
Default Re: best s2000 turbo kit.... 2 choices (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
well said...join the berlina mob...you'd fit right in</TD></TR></TABLE>
Thread Jack: What # of the mob should I report as?
Old 03-05-2008, 12:58 PM
* B A N N E D *
GRAF-FITI's Avatar
#006 sir
welcome aboard
please be as sarcastic as posssible whenever the opportunity presents itself
Old 03-05-2008, 05:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">#006 sir
welcome aboard
please be as sarcastic as posssible whenever the opportunity presents itself</TD></TR></TABLE>
jerks. i think im the only nice one left.
Quick Reply: best s2000 turbo kit.... 2 choices
