How do you remove fuel injectors??
Old 10-31-2002, 06:56 PM
96ek's Avatar
Default How do you remove fuel injectors??
i was wondering if anyonw had a diagram or description of how to remove fuel injectors and or fuel rail with injectors?? ( I did a search and came up with nothing.
Any help is greatly appreciated
Thanks in advance
Old 10-31-2002, 07:26 PM
B19CivicHB's Avatar
Default Re: How do you remove fuel injectors?? (96ek)
Easy.
Unbolt the fuel rail, and bingo, injectors are out. It is literally that easy. Go look at the intake manifold and fuel rail and you'll see how easy it really is.
I believe there are 3 nuts that hold the fuel rail to the intake manifold.
hope that helped a bit,
-Nick-
Old 10-31-2002, 07:27 PM
splitime's Avatar
Default Re: How do you remove fuel injectors?? (B19CivicHB)
release the fuel pressure first, i do the fuel cap and also loosen the nut on the fuel filter....
Old 10-31-2002, 08:06 PM
Evil_Wizard's Avatar
Default Re: How do you remove fuel injectors?? (splitime)
2 minute job. Like he said just release the pressure first.
Old 10-31-2002, 08:35 PM
96ek's Avatar
Default Re: How do you remove fuel injectors?? (Extreme_Hybrid_Hatch)
Do you know where I can find a how-to on this?? If not do you know what size sockets i need and is an extension required?? How do the injectors themselvs come out? any trick to it??
I really appreciate your help on this one. ( Iam going to attempt a fuel injector swap with my friend to see if they are the problem)
Thanks in Advance
Old 10-31-2002, 08:58 PM
96ek's Avatar
up^up^
Old 10-31-2002, 09:09 PM
DeepSi's Avatar
this is how to change the fuel rail but one more step is to yank the fuel injectors out of the IM.
http://www.c-speedracing.com/howto/f.../fuelrail.html
it is pretty easy just take your time, have a shop towel to catch the little excess gas, and be patient
hope this helps
-deepsi
Old 10-31-2002, 09:13 PM
2000si's Avatar
Default Re: How do you remove fuel injectors?? (DeepSi)
i heard that there is a a little screen in front of each injector and if you take that off, you get a little boost in power. has anyone done this, and if so will this effect your motor in any day. any possible problems related to this maybe. oh ya, i have a 00 si
thanks
Old 10-31-2002, 09:14 PM
DeepSi's Avatar
Default Re: How do you remove fuel injectors?? (2000si)
I have not seen these screens that you are talking about. i replaced my fuel injectors and i looked at my fuel injectors and there was no screen infornt of them. I also have a 2000 civic si.
-deepsi
Old 11-01-2002, 08:06 PM
96ek's Avatar
Thanks Alot Deep Si, I really appreciate your help.
So if i understand correctly once you have disconected the fuel rail you just yank the injectors out?? will they get damaged?? any trick??
Sorry about all the questions guys but i really don't want to f*** up anything.
Thanks again
Old 11-02-2002, 07:39 AM
96ek's Avatar
Sorry for the newb questions but I really need the help.
Old 11-03-2002, 08:42 AM
96ek's Avatar
Anyone???
Old 05-23-2013, 12:37 PM
d16y7ohwell's Avatar
thanks
-deepsi
this is on the pressurized side of the fuel injector and i would find it hard to believe removing the screen would have any effect on performance. i would keep them there. theyre there for a reason... to keep crap outta the fuel injector
sorry for the 11 year bump but i figured it was necessary since nobody addressed this
Old 09-02-2013, 10:35 PM
Chris Dodd's Avatar
hello,
thank you for updating the post. i myself was wondering what these "plug/screen" things were. would removing them cause it to run rich? i ordered my injectors off of ebay and 3 of them had the screen and the other did not so i installed them withou the screen. i have 1991 civic si.
B18c1vicrx
04-08-2008 06:21 PM
Ryan124
01-12-2006 09:58 AM
Shadow Templar
01-30-2004 08:25 PM
dabomb
04-17-2003 02:22 PM
baonest
08-05-2001 02:51 PM
Quick Reply: How do you remove fuel injectors??
