does white smoke from exhaust = burning oil
Old 10-30-2002, 07:09 PM
dynomax27's Avatar
Default does white smoke from exhaust = burning oil
Well the civic is finally boosted. I fixed all of my exhaust leaks. Now it seems that im burinig oil or something. After a nice and easy 15 min drive I still see white smoke comming from my car. I know its normal when its cold outside and the car is cold but after 15 min i shouldnt be seeing white smoke. What do you guys think. Also it looks like my turbo is leaking oil too. When i look at the turbo from the bottom i can see oil seaping through the sides where it connects to the turbine.
Old 10-30-2002, 07:10 PM
Kamin's Avatar
Default Re: does white smoke from exhaust = burning oil (dynomax27)
white = coolant
blue = oil
brown/black = fuel
Old 10-31-2002, 06:09 AM
Benj's Avatar
Default Re: does white smoke from exhaust = burning oil (KAMiN)
Maybe you've got a blown head gasket?
Old 10-31-2002, 07:24 AM
nsxmatt's Avatar
Default Re: does white smoke from exhaust = burning oil (Benj)
Most people mistake white for the blue/white type hue that usually comes from burning oil. My guess is if you just put the turbo on, the turbo is leaking oil, and now it starts blowing smoke, it's the leak. Fix the oil leak and see what happens.
Old 10-31-2002, 07:45 AM
Kamin's Avatar
Default Re: does white smoke from exhaust = burning oil (nsxmatt)
this is true
coolant burns WHITE
oil is light blue.
check your seals for the feed and return line on the turbo.
Old 10-31-2002, 12:20 PM
dynomax27's Avatar
ok thanks. the turbo is leaking oil. Should i just say f-it, rebuild it, or get a new one. i really dont want to spend any more money tho.
Old 10-31-2002, 02:57 PM
Bigjon
Guest
Posts: n/a
What would be the first thing to check if you car was burning oil?
Old 10-31-2002, 08:41 PM
civicsitek GanGsTa's Avatar
Default Re: does white smoke from exhaust = burning oil (Bigjon)
Fist thing to check would be how fast you are losing oil. If you are burning it, your oil level will slowly drop.
Old 10-31-2002, 08:46 PM
Evil_Wizard's Avatar
Default Re: does white smoke from exhaust = burning oil (civicsitek)
Maybe your radiator needs to be upgraded to much pressure on it with the turbo now. Having a harder time cooling the engine.
Old 11-01-2002, 02:40 PM
dynomax27's Avatar
Default Re: does white smoke from exhaust = burning oil (Extreme_Hybrid_Hatch)
My radiator actually has a big dent in it form a rock. There are no leaks tho, but it probably does slow down flow.
v8killaz
09-04-2010 05:29 PM
GReddy_Civic
08-11-2008 11:42 AM
mafiaboy757
09-14-2005 08:58 AM
1990civicsi
08-08-2004 06:33 PM
riceburnah
07-22-2004 08:16 AM
Quick Reply: does white smoke from exhaust = burning oil
