trouble mounting my ASR rear 24mm sway bar on my 2000 civic si
Alright fella's, I ordered my ASR 24mm sway bar from weaksauce a few weeks back and decided to put it on tonight. I noticed while trying to line the holes up with the "D" brackets that the holes for the bolts were covered by the bracket when one bolt would go in.
To try and make better sense of it, only one bolt on each side of the D bracket would line up, and the other hole would be covered by the bracket.
This frustrates me, because i remember asking Weaksauce on the phone if the ASR sway bar would work with my Carbing rear lower tie bar, and they were firm with their assurance that it would work.
So I am asking, do I need to have the ASR subframe brace in order to run the sway bar?
Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">How far off is it? A photo would help.</TD></TR></TABLE>
about a solid 1/4".
Pretty much, there are 4 main bolts (2 on each side) of the sway bar that go into the D brackets. I can only line up the top two, or the bottom two.
about a solid 1/4".
Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (Tuner Eddy)
You will have to run the carbing low tie bar on top of the asr brace if thats what your wondering.
Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (.:Made in OC:.)
so do i need to take the tie bar off? because it didnt seem to be in the way at all.
no, i am wondering if i need the ASR subframe brace to run the sway bar....i do not have it.
So you bought the sway bar, but not the brace? How are you mounting it to the subframe.
96-00 Civic subframes are known to be somewhat weaker than 92-95 Civics and 94-01 Integras. I would highly suggest the ASR brace, which should make it a complete bolt-on affair and no worries of subframe tear-out.
Re: (PatrickGSR94)
Pmd!
** You actually need the ASR brace itself to mount their new 24mm setup. I believe there was some miscommunication regarding which brace you have.
Modified by weaksauce.org at 10:47 AM 12/28/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuner Eddy »</TD></TR><TR><TD CLASS="quote">I am wondering if I need the ASR subframe brace to run the sway bar....I do not have it.</TD></TR></TABLE>
YES...and when you get the subframe brace you will be instructed to drill a new hole for the bolt that goes into the D bracket.
Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman »</TD></TR><TR><TD CLASS="quote">
YES...and when you get the subframe brace you will be instructed to drill a new hole for the bolt that goes into the D bracket. </TD></TR></TABLE>
that sucks, i didnt know i'd have to do any drilling.
it will be fine to run my stock lower control arms with this setup correct?
Drilling? On which part? Pmd.
exist12
11-29-2009 10:52 PM
Tuner Eddy
12-28-2007 04:59 PM
