changing dash bulbs on a 1994 accord ex
Old 12-17-2006, 11:55 AM
surf2ithurts's Avatar
Default changing dash bulbs on a 1994 accord ex
Can someone plese tell me how to replace the dash/gage bulbs on a 94 accord ex? What is the actual bulb number? THANKS IN ADVANCE!!!
Old 12-17-2006, 12:10 PM
JDM.Brown's Avatar
Default Re: changing dash bulbs on a 1994 accord ex (surf2ithurts)
Are you refering to the bluish/green bulbs that light the cluster from the back, or the regular bulbs that light the face of the guage and needles from the front? Also are all of the lights out or just one? Are you sure it's not a blown fuse?
Old 12-17-2006, 12:30 PM
Default Re: changing dash bulbs on a 1994 accord ex (JDM.Brown)
They are currently functioning fine. What I want to do is get rid of the stock "greenish color" bulbs that illuminte the cluster i.e. tach and speedometer and replace them with white bulbs. I appreciate the response!
Old 12-17-2006, 05:53 PM
iam7head's Avatar
can't just replace the bulb, the one you have now is oem yellowish white, the light is filter thru a tinted transparent plate/fim.
unless you get rid of the green film, it will not be white
Old 12-17-2006, 06:23 PM
Default Re: changing dash bulbs on a 1994 accord ex (iam7head)
Thanks for the info. 7head! Any advice on removing this film and exactly where is it located? THANKS!
Old 12-17-2006, 06:44 PM
iam7head's Avatar
they are all differently mounted, for my gen, they use a plastic insert that you could remove, some switches are painted with transparent tint, etc.
you can't be sure until you crack it open.
for painted tint, use brake clearner to wipe off the color.
but becareful tho', the insert/tint helps to spread the light evenly
Old 12-18-2006, 01:23 AM
JDM.Brown's Avatar
The bulbs are located on the back of the guage cluster near the top...you must take it out in order to change the lighting. It's a little bit of work to get all of that stuff out of there to get the cluster out.
AyOhOndA
01-25-2011 01:44 PM
95Accord614
12-09-2010 08:55 AM
gbone660
12-11-2004 04:55 PM
accord ex
01-18-2004 04:31 PM
lahight
02-26-2003 01:37 PM
Quick Reply: changing dash bulbs on a 1994 accord ex
