Need Help...Locating Transmission Drain Plug!?!?
Old 08-04-2006, 01:24 PM
Tech-Nics's Avatar
Default Need Help...Locating Transmission Drain Plug!?!?
can some one please post a picture of where the transmission drain plug is?
or atleast explain where its located...im going to do a drain and refill...
thank you...
Old 08-04-2006, 01:55 PM
businessmanph's Avatar
Default Re: Need Help...Locating Transmission Drain Plug!?!? (Tech-Nics)
it's near the front passenger tire
get a 3/8th ratchet
and stick it into the square shaped bolt
Old 08-04-2006, 04:54 PM
sony224422's Avatar
Default Re: Need Help...Locating Transmission Drain Plug!?!? (businessmanph)
its in there pretty tight too.. make sure you use a big rachet
Old 08-04-2006, 07:27 PM
JimBlake's Avatar
Auto or manual tranny? V-6 or 4-cyl? It matters.
Old 08-04-2006, 08:24 PM
Tech-Nics's Avatar
auto/4-cyl
Old 08-04-2006, 10:16 PM
MestizoRacer310's Avatar
Default Re: (Tech-Nics)
Passenger side like businessmanph said. Make sure to use a long handled ratchet...
Old 08-05-2006, 01:24 AM
iam7head's Avatar
Default Re: (MestizoRacer310)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">Passenger side like businessmanph said. Make sure to use a long handled ratchet...</TD></TR></TABLE>
bad idea actually, most people use a long rachet and turn it slowly, because the metal to metal contact it's easy to stripe the bolt that way.
use a regular size handle and give it a quick blow, one good yank will break it loose
Old 08-05-2006, 07:05 PM
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">metal to metal contact it's easy to stripe the bolt that way.
use a regular size handle and give it a quick blow, one good yank will break it loose</TD></TR></TABLE>
What metal to metal contact are you talking about? Not trying to sound dumb or nothing but I don't see what you're speaking of...
Old 08-06-2006, 06:38 AM
Tech-Nics's Avatar
well...the drain and refill was a complete success...thanks to you guys for helping me out...the lug came out with one great big jolt...i used the regular size ratchet. came out like a champ. looks like the person who owned the car before me had atleast 6 1/2 quarts of tranny fluid in before....but now i drained all that crap out and filled it with 4 quarts of Honda ATF...car runs alot better and shifts silky smooth....
thanks again to all that helped me...
Old 08-06-2006, 06:30 PM
thatasiankidtony's Avatar
I used another ATF brand, do you guys think that can be a reason it's shifting hard?
Old 08-06-2006, 06:33 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tech-Nics &raquo;</TD></TR><TR><TD CLASS="quote">... looks like the person who owned the car before me had atleast 6 1/2 quarts of tranny fluid in before....but now i drained all that crap out and filled it with 4 quarts of Honda ATF...car runs alot better and shifts silky smooth....
thanks again to all that helped me...</TD></TR></TABLE>Fill whatever amount makes the correct level on the dipstick. (Car warmed up, shift into park, turn OFF the engine.) Don't simply go by quarts. The tranny & torque converter have something like 7 or 8 quarts in there, but only 1/3 or 1/2 of it can drain out.
Peter_404_21
12-30-2008 08:54 PM
diewX3
03-18-2005 04:18 PM
gulftiresinc
13
09-28-2004 06:23 AM
Matgallis
11-10-2003 01:19 PM
KF_S2000
12-26-2001 01:05 PM
Quick Reply: Need Help...Locating Transmission Drain Plug!?!?
