Old 03-25-2015, 12:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
Map light, dome light went out. Possible Fuse?
Old 07-25-2006, 10:08 PM
uschonda's Avatar
Default Map light, dome light went out. Possible Fuse?
Hi Guys
I was stupid and changing the dome light on the roof with the light on. I was using a flathead and accidentally pushed it in too far.
When I did that the map lights and dome lights went out.
I'm thinking I burned out the fuse. Can anyone tell me which fuse it is and if its easy to replace?
thanks.
Old 07-26-2006, 12:51 AM
0x5359-0055
213374U's Avatar
Default Re: Map light, dome light went out. Possible Fuse? (uschonda)
The fuse should be located under the hood. Very easy to replace.
Old 07-26-2006, 11:09 AM
510cd5's Avatar
Default Re: Map light, dome light went out. Possible Fuse? (213374U)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 213374U &raquo;</TD></TR><TR><TD CLASS="quote">The fuse should be located under the hood. Very easy to replace.</TD></TR></TABLE>
yup should be a number 10. check your spare fuses on the drivers side and grab one of those.
dansaleen_04
07-22-2013 11:19 AM
62maxx
10-25-2006 03:45 PM
Patrick_S
06-08-2006 07:07 AM
crxforum
11-08-2005 01:36 PM
asianalbutt
09-19-2005 03:17 PM
Quick Reply: Map light, dome light went out. Possible Fuse?
